주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ZTE Grand X Max Plus Camera Replacement
필요한 것
    1. ZTE Grand X Max Plus Camera Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Make sure you turn off your phone before starting.
      • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
      • You can also use a hair dryer or a heating gun for this step.
      댓글 쓰기
    2. ZTE Grand X Max Plus Camera Replacement: 2 단계, 이미지 2개 중 1개 ZTE Grand X Max Plus Camera Replacement: 2 단계, 이미지 2개 중 2개
      • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
      • Don't apply too much pressure because the cover can crack easily.
      • To avoid that your cover cracks, you can add tape to back cover.
      • You can use a suction cup to help remove the battery.
      댓글 쓰기
    3. ZTE Grand X Max Plus Camera Replacement: 3 단계, 이미지 2개 중 1개 ZTE Grand X Max Plus Camera Replacement: 3 단계, 이미지 2개 중 2개
      • Carefully remove the cover from the phone.
      댓글 쓰기
    1. ZTE Grand X Max Plus Camera Replacement, Rear Camera: 4 단계, 이미지 2개 중 1개 ZTE Grand X Max Plus Camera Replacement, Rear Camera: 4 단계, 이미지 2개 중 2개
      • Remove the screws from the upper part of the phone using a screwdriver with a JIS #000 head. There are (6) six screws that should be removed.
      댓글 쓰기
    2. ZTE Grand X Max Plus Camera Replacement: 5 단계, 이미지 3개 중 1개 ZTE Grand X Max Plus Camera Replacement: 5 단계, 이미지 3개 중 2개 ZTE Grand X Max Plus Camera Replacement: 5 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to remove the plastic piece that is protecting the motherboard.
      댓글 쓰기
    3. ZTE Grand X Max Plus Camera Replacement: 6 단계, 이미지 1개 중 1개
      • With a plastic opening tool, unclip the camera from the motherboard.
      댓글 쓰기
    4. ZTE Grand X Max Plus Camera Replacement: 7 단계, 이미지 3개 중 1개 ZTE Grand X Max Plus Camera Replacement: 7 단계, 이미지 3개 중 2개 ZTE Grand X Max Plus Camera Replacement: 7 단계, 이미지 3개 중 3개
      • After the camera is unclipped, remove it from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Jordano Baer
회원 가입일: 10/02/17
716 평판
안내서 5개를 작성함
USF Tampa, Team S9-G4, Remmell Fall 2017 USF Tampa, Team S9-G4, Remmell Fall 2017 회원
USFT-REMMELL-F17S9G4
4 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 38
전체 시간: 429
