주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ZTE Maven 3 Back Camera Replacement
필요한 것
  1. ZTE Maven 3 Back Camera Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 ZTE Maven 3 Back Camera Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 ZTE Maven 3 Back Camera Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
    댓글 쓰기
  2. ZTE Maven 3 Back Camera Replacement, Battery: 2 단계, 이미지 3개 중 1개 ZTE Maven 3 Back Camera Replacement, Battery: 2 단계, 이미지 3개 중 2개 ZTE Maven 3 Back Camera Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
    댓글 쓰기
  3. ZTE Maven 3 Back Camera Replacement, Midframe: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
    댓글 쓰기
  4. ZTE Maven 3 Back Camera Replacement: 4 단계, 이미지 1개 중 1개
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
    댓글 쓰기
  5. ZTE Maven 3 Back Camera Replacement: 5 단계, 이미지 2개 중 1개 ZTE Maven 3 Back Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
    댓글 쓰기
  6. ZTE Maven 3 Back Camera Replacement, Back Camera: 6 단계, 이미지 2개 중 1개 ZTE Maven 3 Back Camera Replacement, Back Camera: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Detach the ribbon cable connecting the camera in the top middle of the phone.
    • Use blunt tweezers to pull the camera off and put it aside.
    • Using this same method, grab the tweezers and insert the replacement camera.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jasmine Turner
회원 가입일: 11/01/23
91 평판
안내서 1개를 작성함
UMass Dartmouth, Team 3-1, Konn Fall 2023 UMass Dartmouth, Team 3-1, Konn Fall 2023 회원
UMASSD-KONN-F23S3G1
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 23
전체 시간: 303
