주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ZTE Maven 3 Screen Replacement
필요한 것
  1. ZTE Maven 3 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 ZTE Maven 3 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 ZTE Maven 3 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
    댓글 쓰기
  2. ZTE Maven 3 Screen Replacement, Battery: 2 단계, 이미지 3개 중 1개 ZTE Maven 3 Screen Replacement, Battery: 2 단계, 이미지 3개 중 2개 ZTE Maven 3 Screen Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
    댓글 쓰기
  3. ZTE Maven 3 Screen Replacement, Midframe: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
    댓글 쓰기
  4. ZTE Maven 3 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
    댓글 쓰기
  5. ZTE Maven 3 Screen Replacement: 5 단계, 이미지 2개 중 1개 ZTE Maven 3 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
    댓글 쓰기
  6. ZTE Maven 3 Screen Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
    댓글 쓰기
  7. ZTE Maven 3 Screen Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Please locate the black wire that’s attached to gold plates on the left side of the device.
    • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
    댓글 쓰기
  8. ZTE Maven 3 Screen Replacement: 8 단계, 이미지 2개 중 1개 ZTE Maven 3 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
    • 2 adhesive ribbon cables (green circles).
    • One ribbon cable that slides out (orange circles).
    • Three ribbon cables that pop in and out (yellow circles).
    댓글 쓰기
  9. ZTE Maven 3 Screen Replacement: 9 단계, 이미지 3개 중 1개 ZTE Maven 3 Screen Replacement: 9 단계, 이미지 3개 중 2개 ZTE Maven 3 Screen Replacement: 9 단계, 이미지 3개 중 3개
    • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
    댓글 쓰기
  10. ZTE Maven 3 Screen Replacement: 10 단계, 이미지 2개 중 1개 ZTE Maven 3 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Grab the opening pick and work it into the edges of the motherboard.
    • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
    • Remove the motherboard and put it aside.
    댓글 쓰기
  11. ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: 11 단계, 이미지 2개 중 1개 ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: 11 단계, 이미지 2개 중 2개
    • Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
    댓글 쓰기
  12. ZTE Maven 3 Screen Replacement, Screen: 12 단계, 이미지 1개 중 1개
    • What is left in your hand is now the screen, and any replacement screen will be just as what is in your hand.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Emma Thiboutot
회원 가입일: 10/30/23
705 평판
안내서 8개를 작성함
UMass Dartmouth, Team 3-1, Konn Fall 2023 UMass Dartmouth, Team 3-1, Konn Fall 2023 회원
UMASSD-KONN-F23S3G1
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 343
