소개
This guide has step-by-step instructions on how to replace or remove your ZTE Max XL SIM card tray. To determine if you need to replace your charging port refer to our Troubleshooting Guide.
Note: If the SIM card does not eject in the first step, you will have to complete the full removal guide.
필요한 것
Use the SIM Card Eject Tool to remove the SIM card tray. To do this, insert the key into the hole on the side of the phone near the SIM card tray.
Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide.
Using the iOpener heating pack, CAREFULLY apply heat to the battery. For instructions of how to use the iOpener, use this guide
Disconnect the six connections located on the large circuit board.
The camera itself is lightweight so take care during disconnection of the connector not to lose it.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
My husband cell phone is a zte android and the plug in part was complelty not workimg so he took the back off and all that changed the usb plug in charger part and put his cell back together and it charges and it works besides when je gets on line like google it lets him on for just a swcond and then jt will say lost connection check your netwprk and we have unlimited high speed data is there something he might of accidently done wrong when he replaced the charging part please help
