주요 콘텐츠로 건너뛰기
ZTE Tempo Headphone Jack Replacement
필요한 것
  1. ZTE Tempo Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 1/2 ZTE Tempo Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 2/2
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Headphone Jack Replacement: 2 단계, 이미지 1/3 ZTE Tempo Headphone Jack Replacement: 2 단계, 이미지 2/3 ZTE Tempo Headphone Jack Replacement: 2 단계, 이미지 3/3
    • Unplug wires by pushing up with the plastic opening tool
  3. ZTE Tempo Headphone Jack Replacement: 3 단계, 이미지 1/2 ZTE Tempo Headphone Jack Replacement: 3 단계, 이미지 2/2
    • Push up with the plastic opening tool to remove the motherboard.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the motherboard.
  4. ZTE Tempo Headphone Jack Replacement: 4 단계, 이미지 1/1
    • Unplug the wire by pushing up with the plastic opening tool in the back of the motherboard.
  5. ZTE Tempo Headphone Jack Replacement: 5 단계, 이미지 1/2 ZTE Tempo Headphone Jack Replacement: 5 단계, 이미지 2/2
    • Desolder and remove in front of the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
omar
회원 가입일: 10/02/18
717 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 11
전체 시간: 176
