주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ZTE ZMax Pro Charging Port Replacement
필요한 것
  1. ZTE ZMax Pro Charging Port Replacement, Back Panel Assembly: 1 단계, 이미지 1개 중 1개
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
    댓글 쓰기
  2. ZTE ZMax Pro Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingers, slide the SIM card all the way out of the phone.
    댓글 쓰기
  3. ZTE ZMax Pro Charging Port Replacement: 3 단계, 이미지 2개 중 1개 ZTE ZMax Pro Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
    댓글 쓰기
  4. ZTE ZMax Pro Charging Port Replacement: 4 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
    댓글 쓰기
  5. ZTE ZMax Pro Charging Port Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
    댓글 쓰기
  6. ZTE ZMax Pro Charging Port Replacement: 6 단계, 이미지 2개 중 1개 ZTE ZMax Pro Charging Port Replacement: 6 단계, 이미지 2개 중 2개
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
    댓글 쓰기
  7. ZTE ZMax Pro Charging Port Replacement: 7 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
    댓글 쓰기
  8. ZTE ZMax Pro Charging Port Replacement: 8 단계, 이미지 1개 중 1개
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
    댓글 쓰기
  9. ZTE ZMax Pro Charging Port Replacement, Charging Port: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    댓글 쓰기
  10. ZTE ZMax Pro Charging Port Replacement: 10 단계, 이미지 2개 중 1개 ZTE ZMax Pro Charging Port Replacement: 10 단계, 이미지 2개 중 2개
    • Use tweezers to peel off the tape at the bottom of the phone.
    댓글 쓰기
  11. ZTE ZMax Pro Charging Port Replacement: 11 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool under the charging port board at the bottom of the phone.
    • Push down on the plastic opening tool so the board pulls away from the phone.
    • Continue to do this around the charging port board until it comes all the way off the phone.
    • The board is glued to the case so make sure to work around all edges to ease removal. Trying to pull it away from one edge can cause damage to the board.
    • After removing the charging port, the adhesive will not have as strong of a hold on the new charging port. This should not be an issue. However, if the adhesive strength is negligible, you can consider buying adhesive and applying it before inserting the new charging port.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Nicholas Leacox
회원 가입일: 04/18/18
1,739 평판
안내서 7개를 작성함
Cal Poly, Team S17-G3, Livingston Spring 2018 Cal Poly, Team S17-G3, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G3
4 회원들
안내서 24개를 작성함
11가이드 댓글
Very nice BUT where do you get the replacement charging port?
Anthony Kearns - 답글 공유
Where can I bye the parts
John Anderson - 답글 공유
“Buy” as in purchase not “Bye” as in see you later.
Thomas Heward - 답글 공유
How much is it cost to fix it
anna lightsey - 답글 공유
My charging port was 5.79 with free shipping at
James T. - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 45
전체 시간: 8,663
