주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Zebra ZP 450 Feed Key Replacement
필요한 것
    1. Zebra ZP 450 Feed Key Replacement, Open Lid and Unscrew Screws: 1 단계, 이미지 2개 중 1개 Zebra ZP 450 Feed Key Replacement, Open Lid and Unscrew Screws: 1 단계, 이미지 2개 중 2개
      • This device uses electricity, so it is best to unplug it before going any farther.
      • Remove 5 11.08mm Phillips screws that will come out of the casing once loose.
      • There is one Phillips screw at the bottom center set deep inside the casing - it is easy to get to with a thin screwdriver. This screw will come loose, but stay inside the casing. Don't be surprised when it won't drop out.
      댓글 쓰기
    2. Zebra ZP 450 Feed Key Replacement, Remove Top: 2 단계, 이미지 1개 중 1개
      • Position your hands one on either side of the top.
      • Put your thumbs on the front and your 4 fingers on the sides.
      • Push outwards with your 4 fingers to remove the plastic top.
      • Wiggling the top may help loosen it from the bottom screw that is still in the case.
      댓글 쓰기
    3. Zebra ZP 450 Feed Key Replacement, Open Lid: 3 단계, 이미지 2개 중 1개 Zebra ZP 450 Feed Key Replacement, Open Lid: 3 단계, 이미지 2개 중 2개
      • Put the lid back down and lay the top open as shown in the photo.
      • Be careful setting the lid down, as it could pull wiring from other components. If you need more wiggle room, you can remove the silver cable from the support clip on the side, as seen in the second photo by pulling the tab back and pushing the cable up.
      • The component we are replacing is on the underneath of the top of the device, highlighted in the photo
      댓글 쓰기
    4. Zebra ZP 450 Feed Key Replacement, Remove No-Fuss Ribbon Cable Connectors: 4 단계, 이미지 2개 중 1개 Zebra ZP 450 Feed Key Replacement, Remove No-Fuss Ribbon Cable Connectors: 4 단계, 이미지 2개 중 2개
      • Starting with either ribbon cable, grip it on either side and gently pull out - The cable will come out of it's connector.
      • Repeat for other ribbon cable
      • Ribbons may be fragile, so handle with care.
      댓글 쓰기
    5. Zebra ZP 450 Feed Key Replacement, Remove Circuit Board: 5 단계, 이미지 3개 중 1개 Zebra ZP 450 Feed Key Replacement, Remove Circuit Board: 5 단계, 이미지 3개 중 2개 Zebra ZP 450 Feed Key Replacement, Remove Circuit Board: 5 단계, 이미지 3개 중 3개
      • Remove 2 7.51mm Phillips screws holding the circuit board onto the device casing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Keeland Roche
회원 가입일: 10/11/14
158 평판
안내서 1개를 작성함
USF Tampa, Team 1-28, Donnelly Fall 2014 USF Tampa, Team 1-28, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G28
1 회원
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 39
전체 시간: 2,182
