주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Zoomer Dino Boomer Back Button Replacement
필요한 것
    1. Zoomer Dino Boomer Back Button Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Power off Zoomer Dino Boomer before disassembly.
      • Remove the eight 9.3mm Phillips #1 screws.
      댓글 쓰기
    2. Zoomer Dino Boomer Back Button Replacement: 2 단계, 이미지 2개 중 1개 Zoomer Dino Boomer Back Button Replacement: 2 단계, 이미지 2개 중 2개
      • Turn dinosaur over and hold upright.
      • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
      • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
      댓글 쓰기
    3. Zoomer Dino Boomer Back Button Replacement: 3 단계, 이미지 3개 중 1개 Zoomer Dino Boomer Back Button Replacement: 3 단계, 이미지 3개 중 2개 Zoomer Dino Boomer Back Button Replacement: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
      • Remove back cover.
      • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
      • Do not damage the wires or circuit board.
      댓글 쓰기
    1. Zoomer Dino Boomer Back Button Replacement, Back Button: 4 단계, 이미지 1개 중 1개
      • Where the button is largest, squeeze the two white tabs together.
      댓글 쓰기
    2. Zoomer Dino Boomer Back Button Replacement: 5 단계, 이미지 1개 중 1개
      • Push in the white circular piece between these tabs as far as it will go.
      댓글 쓰기
    3. Zoomer Dino Boomer Back Button Replacement: 6 단계, 이미지 2개 중 1개 Zoomer Dino Boomer Back Button Replacement: 6 단계, 이미지 2개 중 2개
      • Where the button is smallest, squeeze the two white tabs together and press the circular tab in-between them until the button comes loose.
      • Remove the back button.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Lauren Mannix
회원 가입일: 08/29/15
398 평판
안내서 3개를 작성함
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G1
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 39
전체 시간: 2,553
