주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Zoomer Meowzies Back Button Contact Replacement
필요한 것
    1. Zoomer Meowzies Back Button Contact Replacement, Legs: 1 단계, 이미지 3개 중 1개 Zoomer Meowzies Back Button Contact Replacement, Legs: 1 단계, 이미지 3개 중 2개 Zoomer Meowzies Back Button Contact Replacement, Legs: 1 단계, 이미지 3개 중 3개
      • Using the Triangle driver remove the four 7.5 mm screws.
      • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
      댓글 쓰기
    2. Zoomer Meowzies Back Button Contact Replacement: 2 단계, 이미지 2개 중 1개 Zoomer Meowzies Back Button Contact Replacement: 2 단계, 이미지 2개 중 2개
      • Turn the device so that the the device is on its side.
      • Hold the back and belly on the device and gently pull apart.
      • Pulling with too much force might damage a few cables inside, so caution is needed.
      댓글 쓰기
    3. Zoomer Meowzies Back Button Contact Replacement: 3 단계, 이미지 3개 중 1개 Zoomer Meowzies Back Button Contact Replacement: 3 단계, 이미지 3개 중 2개 Zoomer Meowzies Back Button Contact Replacement: 3 단계, 이미지 3개 중 3개
      • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
      댓글 쓰기
    1. Zoomer Meowzies Back Button Contact Replacement, Back Button Contact Point: 4 단계, 이미지 3개 중 1개 Zoomer Meowzies Back Button Contact Replacement, Back Button Contact Point: 4 단계, 이미지 3개 중 2개 Zoomer Meowzies Back Button Contact Replacement, Back Button Contact Point: 4 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Locate the gray rubber contact in the middle of the bottom half of the device. Using the spudger, lift one corner of the contact until it pops loose.
      • Grab the contact and gently pull until the other side detaches.
      • When replacing the contact pad, use the narrow leads on the pad to pull it into place by twisting around the tips of the tweezers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Mitchell Gentry
회원 가입일: 02/14/18
693 평판
안내서 6개를 작성함
USF Tampa, Team S6-G2, Eyestone Spring 2018 USF Tampa, Team S6-G2, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G2
3 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 26
전체 시간: 593
