주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Zune Flash 2nd Generation Communications Board Replacement
필요한 것
    1. Zune Flash 2nd Generation Communications Board Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Zune Flash 2nd Generation Communications Board Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
      • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
      • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
      • PICS MAKE NO SENSE.
      댓글 쓰기
    2. Zune Flash 2nd Generation Communications Board Replacement: 2 단계, 이미지 2개 중 1개 Zune Flash 2nd Generation Communications Board Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
      • You should hear a 'click' as the clip detaches from the device.
      댓글 쓰기
    3. Zune Flash 2nd Generation Communications Board Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
      댓글 쓰기
    4. Zune Flash 2nd Generation Communications Board Replacement: 4 단계, 이미지 3개 중 1개 Zune Flash 2nd Generation Communications Board Replacement: 4 단계, 이미지 3개 중 2개 Zune Flash 2nd Generation Communications Board Replacement: 4 단계, 이미지 3개 중 3개
      • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
      댓글 쓰기
    5. Zune Flash 2nd Generation Communications Board Replacement: 5 단계, 이미지 3개 중 1개 Zune Flash 2nd Generation Communications Board Replacement: 5 단계, 이미지 3개 중 2개 Zune Flash 2nd Generation Communications Board Replacement: 5 단계, 이미지 3개 중 3개
      • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
      댓글 쓰기
    1. Zune Flash 2nd Generation Communications Board Replacement, Communications Board: 6 단계, 이미지 2개 중 1개 Zune Flash 2nd Generation Communications Board Replacement, Communications Board: 6 단계, 이미지 2개 중 2개
      • Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver.
      댓글 쓰기
    2. Zune Flash 2nd Generation Communications Board Replacement: 7 단계, 이미지 2개 중 1개 Zune Flash 2nd Generation Communications Board Replacement: 7 단계, 이미지 2개 중 2개
      • Use your finger to pry back the two clear flaps.
      • Slowly lift the communications board that was held down by the clear flaps.
      • Be careful not to accidentally detach the slim ribbon that connects between the communications board and the device.
      댓글 쓰기
    3. Zune Flash 2nd Generation Communications Board Replacement: 8 단계, 이미지 1개 중 1개
      • Disconnect the ribbon cable with the Zune opening tool by flipping up the black plastic flap where the ribbon cable connects to the memory board.
      • Pull the ribbon cable out of the memory board.
      댓글 쓰기
    4. Zune Flash 2nd Generation Communications Board Replacement: 9 단계, 이미지 1개 중 1개
      • Peal the slim ribbon cable off the communications board using your fingers.
      • This slim ribbon is attached using an adhesive, so it cannot be reattached without more adhesive.
      댓글 쓰기
    5. Zune Flash 2nd Generation Communications Board Replacement: 10 단계, 이미지 2개 중 1개 Zune Flash 2nd Generation Communications Board Replacement: 10 단계, 이미지 2개 중 2개
      • Pull the cable connector straight up using your fingers.
      • Communications board remains.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
ybahman
회원 가입일: 11/01/09
139 평판
안내서 4개를 작성함
Cal Poly, Team 9-20, Regan Fall 2009 Cal Poly, Team 9-20, Regan Fall 2009 회원
CPSU-REGAN-F09S9G20
5 회원들
안내서 27개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 26
전체 시간: 3,987
