주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
eMac AirPort Card Replacement
필요한 것
    1. eMac AirPort Card Replacement, AirPort Card: 1 단계, 이미지 1개 중 1개
      • Installation of the AirPort Card on this machine is very easy.
      • The AirPort slot is located just above the Optical Drive in the front of the unit. It is covered by a small plastic panel.
      댓글 쓰기
    2. eMac AirPort Card Replacement: 2 단계, 이미지 2개 중 1개 eMac AirPort Card Replacement: 2 단계, 이미지 2개 중 2개
      • Press the eject arrow located on the upper right corner of your keyboard. Once the optical drive tray is open, gently hold it and shut down the machine.
      • Remove the two Phillips screws located to the right and left sides of the optical drive tray.
      • The Airport cable is snapped into place on the back of the optical drive panel .
      • Gently remove the panel from the front of the eMac
      • Disconnect the AirPort cable from the optical drive panel.
      • Pull the AirPort card straight away from its socket in the eMac.
      댓글 쓰기
    3. eMac AirPort Card Replacement: 3 단계, 이미지 2개 중 1개 eMac AirPort Card Replacement: 3 단계, 이미지 2개 중 2개
      • Slide the new AirPort card into the slot until its firmly seated.
      • Reconnect the AirPort cable to the optical drive panel.
      • Reattach the optical drive panel and restart the eMac.
      • To configure the AirPort card, go under the Apple in the upper left hand corner to System Preferences - Network. The AirPort option should be on the left hand window. Select it.
      • It should set up on its own. If not hit the "Assist Me" box on the bottom of the page.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 22명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
mayer
회원 가입일: 01/04/10
690,441 평판
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 75
전체 시간: 28,503
