주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
eMac PRAM Battery Replacement
필요한 것
    1. eMac PRAM Battery Replacement, PRAM Battery: 1 단계, 이미지 2개 중 1개 eMac PRAM Battery Replacement, PRAM Battery: 1 단계, 이미지 2개 중 2개
      • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
      댓글 쓰기
    2. eMac PRAM Battery Replacement: 2 단계, 이미지 2개 중 1개 eMac PRAM Battery Replacement: 2 단계, 이미지 2개 중 2개
      • The access panel is held in place by one Phillips screw. Unscrew it.
      • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
      댓글 쓰기
    3. eMac PRAM Battery Replacement: 3 단계, 이미지 1개 중 1개
      • The battery is located just to the left and below the RAM slots.
      • Note the positive is to the right and negative to the left. There is a + sign located on the logic board to the right of the battery.
      • Care must be taken when removing the battery to prevent it dropping into the machine. It pulls straight out. Use a small instrument like a dental pick or flathead screwdriver to lift the + end out. I use a large hemostat to hold the battery.
      • After removal of the old battery and replace with a new one by pressing it into place.
      • Replace the access panel. Turn it over and plug it in. Start up and go under the Apple to System Preferences - System - Date & Time. If you have an internet connection check the box to automatically and select Apple Americas.
      • If no internet just set the date and time manually.
      • Next select the Time Zone box. Click the curser on the map to the closest city to you.
      • Next click the Clock box and select the type of display you prefer.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 27명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
mayer
회원 가입일: 01/04/10
690,441 평판
안내서 11개를 작성함
1가이드 댓글
Alguien sabe el.modo serie de la batería???? Todo muy bien pero faltó lomas importante el modelo serie o número de pieza de la bateria
ru vera - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 77
전체 시간: 24,929
