주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
eufy Security SpaceView Monitor Display Assembly
필요한 것
    1. eufy Security SpaceView Monitor Display Assembly, Display Assembly: 1 단계, 이미지 2개 중 1개 eufy Security SpaceView Monitor Display Assembly, Display Assembly: 1 단계, 이미지 2개 중 2개
      • Use an opening tool to press into the opening notches built into the lower portion of the display.
      • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
      • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
      • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
      댓글 쓰기
    2. eufy Security SpaceView Monitor Display Assembly, Lift the display: 2 단계, 이미지 1개 중 1개
      • Lift the display up and away from the housing.
      • Take care to not twist or pull on the ribbon connector.
      댓글 쓰기
결론
To reassemble, lay the display in its original orientation on top of the housing, and apply even force to the edges of the display. It should click each time, and securely itself tightly to the housing.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
ZFarley
회원 가입일: 10/31/23
422 평판
안내서 3개를 작성함
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 회원
UMASSD-GULBRANDSEN-F23S2G5
3 회원들
안내서 12개를 작성함
1가이드 댓글
I need a new ribbon connector. How do I fix?
Karen Bottai - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 36
전체 시간: 1,281
