주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iBUYPOWER Y40 IBP Thermal Paste Replacement
필요한 것
  1. iBUYPOWER Y40 IBP Thermal Paste Replacement, Thermal Paste: 1 단계, 이미지 1개 중 1개
    • Shut down the computer completely and unplug the power cable before opening the case.
    • Allow the system to cool for several minutes before you begin the repair.
    • Never work inside the computer while it is still connected to power.
    댓글 쓰기
  2. iBUYPOWER Y40 IBP Thermal Paste Replacement: 2 단계, 이미지 3개 중 1개 iBUYPOWER Y40 IBP Thermal Paste Replacement: 2 단계, 이미지 3개 중 2개 iBUYPOWER Y40 IBP Thermal Paste Replacement: 2 단계, 이미지 3개 중 3개
    • Carefully remove the tempered glass side panel to access the internal components of the desktop.
    • Place the panel somewhere safe to avoid scratches or damage.
    • Handle the glass panel carefully to prevent breakage or scratches.
    • Identify the CPU cooler mounted on top of the processor. It must be removed to access the processor and replace the thermal paste.
    • In this system, a liquid CPU cooler is installed with a pump block connected to the radiator.
    댓글 쓰기
  3. iBUYPOWER Y40 IBP Thermal Paste Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to loosen the CPU cooler screws in a cross pattern, loosening each screw gradually to avoid uneven pressure.
    댓글 쓰기
  4. iBUYPOWER Y40 IBP Thermal Paste Replacement: 4 단계, 이미지 1개 중 1개
    • Gently lift the CPU cooler straight out from the processor.
    • If it feels stuck, slightly twist it to break the seal of the old thermal paste before lifting.
    • Do not touch the surface of the CPU with your fingers, as oils from your skin can affect performance.
    댓글 쓰기
  5. iBUYPOWER Y40 IBP Thermal Paste Replacement: 5 단계, 이미지 1개 중 1개
    • Apply a small amount of 90% isopropyl alcohol to a microfiber cloth and gently wipe the old thermal paste from both the CPU and the bottom of the cooler.
    • Continue cleaning until both surfaces are completely clean and dry.
    • Apply a pea-sized amount of new thermal paste to the center of the CPU.
    댓글 쓰기
  6. iBUYPOWER Y40 IBP Thermal Paste Replacement: 6 단계, 이미지 1개 중 1개
    • Place the CPU cooler back over the processor and align it with the mounting holes.
    • Tighten the screws evenly to secure the CPU cooler in place.
    • Check that the CPU cooler is properly seated and all screws are tightened securely.
    댓글 쓰기
  7. iBUYPOWER Y40 IBP Thermal Paste Replacement: 7 단계, 이미지 1개 중 1개
    • Reconnect the power cable, close the case, and power on the system.
    댓글 쓰기
결론
To reassemble your device, follow these steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Jaylen Emanuel
회원 가입일: 02/27/26
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 74
