주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iBook G3 12" RAM Replacement
필요한 것
    1. iBook G3 12" RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      댓글 쓰기
    1. iBook G3 12" RAM Replacement, Keyboard: 2 단계, 이미지 1개 중 1개
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      댓글 쓰기
    2. iBook G3 12" RAM Replacement: 3 단계, 이미지 1개 중 1개
      • If the computer does not have an Airport card installed, skip the next two steps.
      • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
      댓글 쓰기
    3. iBook G3 12" RAM Replacement: 4 단계, 이미지 1개 중 1개
      • Grasp the clear plastic tab on the Airport card and pull toward the right.
      댓글 쓰기
    4. iBook G3 12" RAM Replacement: 5 단계, 이미지 1개 중 1개
      • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
      댓글 쓰기
    5. iBook G3 12" RAM Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
      댓글 쓰기
    6. iBook G3 12" RAM Replacement: 7 단계, 이미지 1개 중 1개
      • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
      댓글 쓰기
    7. iBook G3 12" RAM Replacement: 8 단계, 이미지 1개 중 1개
      • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
      댓글 쓰기
    1. iBook G3 12" RAM Replacement, RAM: 9 단계, 이미지 1개 중 1개
      • Your laptop should look approximately like this.
      댓글 쓰기
    2. iBook G3 12" RAM Replacement: 10 단계, 이미지 1개 중 1개
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the chip directly out from its connectors.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 47명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
5다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 75
전체 시간: 34,747
