주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iBook G3 Clamshell RAM Replacement
필요한 것
    1. iBook G3 Clamshell RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use a coin to turn both battery locking screws 90 degrees to the left.
      • Remove the battery cover.
      • Remove the battery from the computer by pulling up on the plastic tab.
      댓글 쓰기
    1. iBook G3 Clamshell RAM Replacement, Airport Card: 2 단계, 이미지 1개 중 1개
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
      • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
      댓글 쓰기
    2. iBook G3 Clamshell RAM Replacement: 3 단계, 이미지 1개 중 1개
      • If your computer does not have an airport card, you can skip the next two steps.
      • Grasp the clear plastic tab on the airport card and pull up and toward the display.
      댓글 쓰기
    3. iBook G3 Clamshell RAM Replacement: 4 단계, 이미지 1개 중 1개
      • Hold the airport card in one hand and use your other hand to remove the antenna cable.
      댓글 쓰기
    1. iBook G3 Clamshell RAM Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
      • Remove the two Phillips screws that secure the RAM shield.
      댓글 쓰기
    2. iBook G3 Clamshell RAM Replacement: 6 단계, 이미지 1개 중 1개
      • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
      댓글 쓰기
    3. iBook G3 Clamshell RAM Replacement: 7 단계, 이미지 1개 중 1개
      • Pull up the keyboard connector cable by its clear plastic loop.
      댓글 쓰기
    1. iBook G3 Clamshell RAM Replacement, RAM: 8 단계, 이미지 1개 중 1개
      • Your laptop should look approximately like this.
      댓글 쓰기
    2. iBook G3 Clamshell RAM Replacement: 9 단계, 이미지 1개 중 1개
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the chip directly out from its connectors.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
7다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
1가이드 댓글
I love that iFixit will sell you a quarter ($0.25) for $2.99 plus tax and shipping, another $3.29 shipping (totally reasonable), and sales tax for my location - the total is $6.59. I wish I could sell quarters for $6.59. 🤣
UnCoopervised - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 90
전체 시간: 24,661
