주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iFixit Precision Bit Driver Reassembly
필요한 것
  1. iFixit Precision Bit Driver Reassembly, How to reinstall the bearing cap: 1 단계, 이미지 3개 중 1개 iFixit Precision Bit Driver Reassembly, How to reinstall the bearing cap: 1 단계, 이미지 3개 중 2개 iFixit Precision Bit Driver Reassembly, How to reinstall the bearing cap: 1 단계, 이미지 3개 중 3개
    • Unscrew the center of the barrel
    • Note: Assembly utilizes threat locker. You may need tools to unscrew. Use a small piece of duct tape on the smooth part to protect the aluminum.
    • Use pliers on the duct tape, and an adjustable wrench on the flat of the knurled part near the bottom of the screw driver to create leverage to unscrew the barrel.
    댓글 쓰기
  2. iFixit Precision Bit Driver Reassembly: 2 단계, 이미지 3개 중 1개 iFixit Precision Bit Driver Reassembly: 2 단계, 이미지 3개 중 2개 iFixit Precision Bit Driver Reassembly: 2 단계, 이미지 3개 중 3개
    • Next use a 2.5mm hex key with a long shaft such that it fits all the way through the top half of the screw driver.
    • Insert the bearing/top assembly onto the hex key, and begin tightening the bearing assembly into the screwdriver.
    • Note: threadlocker should not be necessary here as there is an O ring that is responsible for maintaining the thread loading
    댓글 쓰기
  3. iFixit Precision Bit Driver Reassembly: 3 단계, 이미지 1개 중 1개
    • Screw the two halves of the barrel back together.
    • While not necessary, some thread locker can be applied to the threads on the upper half of the barrel to prevent the two halves from separating. Be sure to use non-permanent thread locker in case you need to do this again in the future!
    댓글 쓰기
  4. iFixit Precision Bit Driver Reassembly: 4 단계, 이미지 1개 중 1개
    • Voila, enjoy your screw driver.
    댓글 쓰기
결론
There are other ways to do this, such as the floss trick. But if you have the tools lying around here's the proper way to reassemble your iFixit Precision screwdriver!
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ricky H
회원 가입일: 04/13/12
199 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 44
지난 30일: 123
전체 시간: 1,866
