주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iFixit Screwdriver Grip Replacement
필요한 것
    1. iFixit Screwdriver Grip Replacement, Grip: 1 단계, 이미지 1개 중 1개
      • Your iFixit screwdriver has seen better days. Its been in one to many tight places and its mated with far too many screw faces. Its been a part of so many fixes that it seriously would appreciate some down time.
      • But no, you want to keep using this driver. You want it to weather the next fix. It's just not performing like it used to in its glory days.
      • So what is this anyway? A guide to fix a screwdriver? You bet.
      댓글 쓰기
    2. iFixit Screwdriver Grip Replacement: 2 단계, 이미지 3개 중 1개 iFixit Screwdriver Grip Replacement: 2 단계, 이미지 3개 중 2개 iFixit Screwdriver Grip Replacement: 2 단계, 이미지 3개 중 3개
      • If you're an owner of the original iFixit screwdriver included in the 54 Bit Driver Kit, you've probably noticed that the rubber grip rings on the screw driver wear out over time, develop small tears and fall off.
      • Regardless if they wear from over-torquing or the build up of oils from your hands, it's quite frustrating to lose the grip on a prised screwdriver.
      댓글 쓰기
    3. iFixit Screwdriver Grip Replacement: 3 단계, 이미지 2개 중 1개 iFixit Screwdriver Grip Replacement: 3 단계, 이미지 2개 중 2개
      • Here's the solution: throw some o-rings on it.
      • 1/16in thick, 7/16 OD, 5/16 ID work wonders.
      • OD= outside diameter.
      • ID= inside diameter.
      • I picked up a bunch from my local hardware store. They are manufactured by Midwest Fastner. They cost $0.31 USD each.
      댓글 쓰기
    4. iFixit Screwdriver Grip Replacement: 4 단계, 이미지 1개 중 1개
      • So how do you remove the old grip? Simple, use your fingernails!
      • Otherwise, use toothpicks!
      • Remember the mohs scale? Wood won't carelessly scratch your metal tool!
      댓글 쓰기
    5. iFixit Screwdriver Grip Replacement: 5 단계, 이미지 2개 중 1개 iFixit Screwdriver Grip Replacement: 5 단계, 이미지 2개 중 2개
      • That's it. If your grip's gone, shower your screwdriver in o-rings.
      • Enjoy that new, glistening rubber grip on your screwdriver.
      댓글 쓰기
결론
To reassemble your screwdriver, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Anthony Kouttron
회원 가입일: 02/24/17
5,764 평판
안내서 5개를 작성함
2가이드 댓글
Worked like a charm.
Now all I need is to get instructions on how to assemble a replacement 54-bit driver kit case….
Jason Higley - 답글 공유
Thanks for publishing the sizes on this. I have rejuvenated my driver grip.
However, like the other poster, the plastic storage case on mine has cracked and I too would want a replacement.
alan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 90
전체 시간: 3,648
