주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iHome IBT16 Battery Replacement
필요한 것
  1. iHome IBT16 Battery Replacement, Base Plate: 1 단계, 이미지 2개 중 1개 iHome IBT16 Battery Replacement, Base Plate: 1 단계, 이미지 2개 중 2개
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
    댓글 쓰기
  2. iHome IBT16 Battery Replacement: 2 단계, 이미지 2개 중 1개 iHome IBT16 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
    댓글 쓰기
  3. iHome IBT16 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Inside the iHome remove the two 10mm silver Phillips screws that are on the motherboard.
    • Connect the ground strap to earth ground and put it around your wrist.
    댓글 쓰기
  4. iHome IBT16 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Take the motherboard out of the device, use the Plastic opening tool to ensure the power switch doesn't get stuck.
    • Don't pull too hard as you could possibly rip some wires or break the switch.
    댓글 쓰기
  5. iHome IBT16 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Take the battery out from underneath the motherboard.
    • The battery is connected to the motherboard, don't pull the battery too hard or too far from the motherboard.
    댓글 쓰기
  6. iHome IBT16 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Unsolder the black and red wires that are connected to the motherboard.
    • Don't hold the soldering iron to the solder joints for more than 10 seconds at a time.
    댓글 쓰기
  7. iHome IBT16 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the bad battery by unsoldering the red wire from the B+ solder joint and the black wire from the B-
    댓글 쓰기
결론
To put it all back together, solder the battery wires to the correct solder joints. Then place the battery back under the motherboard and screw the motherboard back on. After that put the face plate back on, and screw on the face plate
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Steven Ferreira
회원 가입일: 03/08/17
222 평판
안내서 2개를 작성함
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 UMass Dartmouth, Team S3-G6, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G6
2 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 35
전체 시간: 2,709
