주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iHome IBT16 Micro USB port Replacement
필요한 것
  1. iHome IBT16 Micro USB port Replacement, Base Plate: 1 단계, 이미지 2개 중 1개 iHome IBT16 Micro USB port Replacement, Base Plate: 1 단계, 이미지 2개 중 2개
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
    댓글 쓰기
  2. iHome IBT16 Micro USB port Replacement: 2 단계, 이미지 2개 중 1개 iHome IBT16 Micro USB port Replacement: 2 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
    댓글 쓰기
  3. iHome IBT16 Micro USB port Replacement, Micro USB port: 3 단계, 이미지 1개 중 1개
    • Inside the iHome remove the two silver Phillips screws that are on the motherboard.
    • Connect the ground strap to ground, and then put the strap around your wrist.
    댓글 쓰기
  4. iHome IBT16 Micro USB port Replacement: 4 단계, 이미지 1개 중 1개
    • Take the motherboard out of the device, use the plastic opening tool to ensure the power switch doesn't get stuck.
    댓글 쓰기
  5. iHome IBT16 Micro USB port Replacement: 5 단계, 이미지 1개 중 1개
    • On the other side of the motherboard unsolder the two biggest solder joints under the micro USB.
    댓글 쓰기
  6. iHome IBT16 Micro USB port Replacement: 6 단계, 이미지 1개 중 1개
    • On the side of the motherboard that the micro USB connector is there are five surface mount solder joints at the back of the connector. Unsolder these five solder joints.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Steven Ferreira
회원 가입일: 03/08/17
222 평판
안내서 2개를 작성함
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 UMass Dartmouth, Team S3-G6, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G6
2 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 19
전체 시간: 1,715
