주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iHome IBT16 Power Switch Replacement
필요한 것
  1. iHome IBT16 Power Switch Replacement, Base Plate: 1 단계, 이미지 2개 중 1개 iHome IBT16 Power Switch Replacement, Base Plate: 1 단계, 이미지 2개 중 2개
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
    댓글 쓰기
  2. iHome IBT16 Power Switch Replacement: 2 단계, 이미지 2개 중 1개 iHome IBT16 Power Switch Replacement: 2 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
    댓글 쓰기
  3. iHome IBT16 Power Switch Replacement, Power Switch: 3 단계, 이미지 2개 중 1개 iHome IBT16 Power Switch Replacement, Power Switch: 3 단계, 이미지 2개 중 2개
    • Using the Philips #00 screwdriver, unscrew and remove the two silver 10mm screws holding the motherboard
    • Don't misplace the screws! Keep them in a safe place while working on the device
    • Make sure to ground yourself prior to continuing at this point
    댓글 쓰기
  4. iHome IBT16 Power Switch Replacement: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, pull the motherboard out of the casing
    • Make sure to lift it out at an angle to the back, as the plastic power switch is attached to the board and can be broken
    댓글 쓰기
  5. iHome IBT16 Power Switch Replacement: 5 단계, 이미지 2개 중 1개 iHome IBT16 Power Switch Replacement: 5 단계, 이미지 2개 중 2개
    • Desolder the 10 points holding the power switch to the motherboard
    • Once complete, simply remove the switch from the board
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ryan Edwards
회원 가입일: 03/21/17
331 평판
안내서 3개를 작성함
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 UMass Dartmouth, Team S3-G6, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G6
2 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 1,049
