주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iHome iH27B Power Connector Replacement
필요한 것
    1. iHome iH27B Power Connector Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
      • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
      • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
      댓글 쓰기
    2. iHome iH27B Power Connector Replacement: 2 단계, 이미지 3개 중 1개 iHome iH27B Power Connector Replacement: 2 단계, 이미지 3개 중 2개 iHome iH27B Power Connector Replacement: 2 단계, 이미지 3개 중 3개
      • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
      • Remove the plastic slide from its location and set it aside.
      • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
      • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
      • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
      • Set the plastic covering and the watch battery aside.
      댓글 쓰기
    3. iHome iH27B Power Connector Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the following screws:
      • Eight 10 mm using the Phillips #0 on the bottom of your device.
      • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
      댓글 쓰기
    4. iHome iH27B Power Connector Replacement: 4 단계, 이미지 1개 중 1개
      • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
      • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
      댓글 쓰기
    5. iHome iH27B Power Connector Replacement: 5 단계, 이미지 1개 중 1개
      • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
      • You should have visible access to most of the components inside the iHome now.
      댓글 쓰기
    1. iHome iH27B Power Connector Replacement, Power Connector: 6 단계, 이미지 2개 중 1개 iHome iH27B Power Connector Replacement, Power Connector: 6 단계, 이미지 2개 중 2개
      • Firmly grasp the power connector, which is the plastic rectangular piece with the white and black wires connected to it.
      • Pull upwards and dislodge the connector.
      댓글 쓰기
    2. iHome iH27B Power Connector Replacement: 7 단계, 이미지 1개 중 1개
      • Using the scissors on your wire strippers, cut the connecting wires.
      • Using your wire strippers, remove about 1/4 " of the plastic tubing surrounding the end of your exposed wire, careful to not damage the wires.
      • Using a wire-nut or electrician's tape, connect the wires of the replacement power connector to your exposed wires. Connect white wire to white, and black to black.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
John Kraemer
회원 가입일: 10/09/12
76 평판
안내서 9개를 작성함
Cal Poly, Team 3-21, Amido Fall 2012 Cal Poly, Team 3-21, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G21
4 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 41
전체 시간: 2,524
