주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iHome iH8BR iPod Adapter Replacement
필요한 것
    1. iHome iH8BR iPod Adapter Replacement, Lower Case: 1 단계, 이미지 3개 중 1개 iHome iH8BR iPod Adapter Replacement, Lower Case: 1 단계, 이미지 3개 중 2개 iHome iH8BR iPod Adapter Replacement, Lower Case: 1 단계, 이미지 3개 중 3개
      • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
      • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
      • Remove the battery cover and the batteries.
      댓글 쓰기
    2. iHome iH8BR iPod Adapter Replacement: 2 단계, 이미지 2개 중 1개 iHome iH8BR iPod Adapter Replacement: 2 단계, 이미지 2개 중 2개
      • Slide a spudger under the two front rubber pads to expose two hidden screws.
      댓글 쓰기
    3. iHome iH8BR iPod Adapter Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the following eight screws:
      • Four 15.1 mm Phillips #2 screws near the front of the device.
      • Four 12.7 mm Phillips #2 screws near the back of the device.
      • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
      댓글 쓰기
    4. iHome iH8BR iPod Adapter Replacement: 4 단계, 이미지 2개 중 1개 iHome iH8BR iPod Adapter Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
      • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
      • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
      • The lower case can now be completely removed from the device!
      댓글 쓰기
    1. iHome iH8BR iPod Adapter Replacement, Motherboard Assembly: 5 단계, 이미지 2개 중 1개 iHome iH8BR iPod Adapter Replacement, Motherboard Assembly: 5 단계, 이미지 2개 중 2개
      • Remove the four screws attaching the top of the case to the motherboard:
      • Two 9.5 mm Phillips #2 screws near the speaker grille.
      • Two 14.3 mm Phillips #2 screws that sit in recesses under the motherboard.
      • It is useful to use a screwdriver with a magnetic tip so that the screws don't get lost inside the device.
      댓글 쓰기
    2. iHome iH8BR iPod Adapter Replacement: 6 단계, 이미지 2개 중 1개 iHome iH8BR iPod Adapter Replacement: 6 단계, 이미지 2개 중 2개
      • Turn the iHome 180 degrees and carefully pull up on speaker cases to pry them loose from the bottom case.
      • Prying the Motherboard Assembly from the Upper Case will require a good amount of force. Be very careful not to break the case, or yank on any of the ribbon wires attached to the underside.
      • Pulling outwards on the sides of the Upper Casing can help loosen the assembly.
      • If it seems too difficult to remove, chances are that a screw is still attached. Make sure you've removed every screw listed before proceeding to this step.
      • Pull the back adapter cover off.
      댓글 쓰기
    3. iHome iH8BR iPod Adapter Replacement: 7 단계, 이미지 2개 중 1개 iHome iH8BR iPod Adapter Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the four 6.4 mm Phillips #1 screws holding the adapter to the outer case.
      • Only remove the following screws if you are planning on taking apart the iPod Adapter later on:
      • Two 6.4 mm Phillips #1 screws near the center of the adapter. These screws have built in washers.
      • One 4.0 mm Phillips #1 screw near the center of the adapter.
      • The iPod adapter should now be separate from the upper casing.
      댓글 쓰기
    4. iHome iH8BR iPod Adapter Replacement: 8 단계, 이미지 3개 중 1개 iHome iH8BR iPod Adapter Replacement: 8 단계, 이미지 3개 중 2개 iHome iH8BR iPod Adapter Replacement: 8 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • With the back of the iHome is facing you, tilt the Motherboard Assembly upwards as shown.
      • Do not yank or jerk these ribbon cables. Make sure not to pull on the heads, but on the ribbons themselves.
      • Use tweezers to remove the 6 ribbon cables.
      댓글 쓰기
    5. iHome iH8BR iPod Adapter Replacement: 9 단계, 이미지 1개 중 1개
      • Pull the speakers, motherboard, and iPod adapter up and away from the lower casing.
      • You have now separated your iHome's inner workings from its protective case!
      댓글 쓰기
    1. iHome iH8BR iPod Adapter Replacement, iPod Adapter: 10 단계, 이미지 2개 중 1개 iHome iH8BR iPod Adapter Replacement, iPod Adapter: 10 단계, 이미지 2개 중 2개
      • Remove the two 1.8 mm Phillips #2 black screws from iPod stand.
      • You can now separate the iPod adapter from its casing!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
cfredric
회원 가입일: 04/17/13
70 평판
안내서 6개를 작성함
Cal Poly, Team 12-33, Amido Spring 2013 Cal Poly, Team 12-33, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G33
4 회원들
안내서 63개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 24
전체 시간: 1,540
