주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iHome iP21 Display LED Replacement
필요한 것
    1. iHome iP21 Display LED Replacement, Base: 1 단계, 이미지 3개 중 1개 iHome iP21 Display LED Replacement, Base: 1 단계, 이미지 3개 중 2개 iHome iP21 Display LED Replacement, Base: 1 단계, 이미지 3개 중 3개
      • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
      • Unscrew the four 11mm screws from the base.
      • Pry the base loose using the spudger.
      • Remove the base by hand.
      댓글 쓰기
    2. iHome iP21 Display LED Replacement, Housing: 2 단계, 이미지 2개 중 1개 iHome iP21 Display LED Replacement, Housing: 2 단계, 이미지 2개 중 2개
      • Remove the two black 6mm screws connecting the main circuit board to the housing top.
      • Gently pull front housing from the back housing.
      댓글 쓰기
    1. iHome iP21 Display LED Replacement, Remove Speaker Assembly: 3 단계, 이미지 1개 중 1개
      • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
      댓글 쓰기
    2. iHome iP21 Display LED Replacement, Remove speaker from speaker assembly: 4 단계, 이미지 2개 중 1개 iHome iP21 Display LED Replacement, Remove speaker from speaker assembly: 4 단계, 이미지 2개 중 2개
      • Lift speaker assembly
      • Remove four 7mm screws to detach speaker from speaker assembly
      댓글 쓰기
    1. iHome iP21 Display LED Replacement, Display circuit board: 5 단계, 이미지 3개 중 1개 iHome iP21 Display LED Replacement, Display circuit board: 5 단계, 이미지 3개 중 2개 iHome iP21 Display LED Replacement, Display circuit board: 5 단계, 이미지 3개 중 3개
      • Remove six 6mm screws from display circuit board.
      • Press black holding clips down and outward to release display circuit board.
      • Lift display circuit board to detach it from the housing.
      댓글 쓰기
    2. iHome iP21 Display LED Replacement, Cables: 6 단계, 이미지 2개 중 1개 iHome iP21 Display LED Replacement, Cables: 6 단계, 이미지 2개 중 2개
      • Desolder the solder joints connecting the grounding cable to the display circuit board.
      • Remove glue from the ribbon cables with your fingers. Grasp and pull the glue to remove it from the circuit board.
      • Desolder the solder joints connecting the three ribbon cables to the back of the display circuit board.
      • Desolder the solder joints connecting the two grounding cables to the back of the display circuit board.
      • Desolder the solder joints connecting the two grounding cables to the back of the main housing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Brandy
회원 가입일: 10/27/14
601 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 553
