주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iHome iPL8 Lightning Connector Replacement
필요한 것
    1. iHome iPL8 Lightning Connector Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Turn the device over to access the bottom panel.
      • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
      댓글 쓰기
    2. iHome iPL8 Lightning Connector Replacement: 2 단계, 이미지 1개 중 1개
      • Using a Phillips #2 screwdriver, unscrew the captive screw.
      • Keep turning until the screw and the door are loose.
      댓글 쓰기
    3. iHome iPL8 Lightning Connector Replacement: 3 단계, 이미지 1개 중 1개
      • Lift and remove the battery access panel.
      • The captive screw will remain attached to the panel.
      댓글 쓰기
    4. iHome iPL8 Lightning Connector Replacement: 4 단계, 이미지 2개 중 1개 iHome iPL8 Lightning Connector Replacement: 4 단계, 이미지 2개 중 2개
      • Gently press on the rim of the 3V battery.
      • Remove the 3V battery.
      댓글 쓰기
    1. iHome iPL8 Lightning Connector Replacement, Lightning Connector: 5 단계, 이미지 1개 중 1개
      • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
      • Remove the four 6mm Phillips #2 screws.
      댓글 쓰기
    2. iHome iPL8 Lightning Connector Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the four round pads from the bottom of the device.
      • There are two additional 6mm Phillips #2 screws under the pads.
      • Using a Phillips #2 screwdriver, remove the two remaining screws.
      • Put your hand on the silver bottom case and gently pull it outward.
      댓글 쓰기
    3. iHome iPL8 Lightning Connector Replacement: 7 단계, 이미지 2개 중 1개 iHome iPL8 Lightning Connector Replacement: 7 단계, 이미지 2개 중 2개
      • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
      • Pull out the green circuit board on the two corners.
      • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
      댓글 쓰기
    4. iHome iPL8 Lightning Connector Replacement: 8 단계, 이미지 2개 중 1개 iHome iPL8 Lightning Connector Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
      • Remove the two screws and the black cover.
      • Gently remove the lightning dock assembly.
      • The lightning dock assembly is connected to wires.
      댓글 쓰기
    5. iHome iPL8 Lightning Connector Replacement: 9 단계, 이미지 3개 중 1개 iHome iPL8 Lightning Connector Replacement: 9 단계, 이미지 3개 중 2개 iHome iPL8 Lightning Connector Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
      • Remove the back cover.
      • Use your fingers to reposition the lightning connector.
      • Make sure ALL of the lightning connector is exposed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Chen Zhong
회원 가입일: 02/05/19
569 평판
안내서 4개를 작성함
UC Davis, Team S18-G5, Lore Winter 2019 UC Davis, Team S18-G5, Lore Winter 2019 회원
UCD-LORE-W19S18G5
3 회원들
안내서 8개를 작성함
3가이드 댓글
where can I find the replacement lightning connector?
Bond 007 and a Half - 답글 공유
Greetings, did you ever find the connector replacement? I am asking so that I can purchase. Thank you in advance for your reply.
Shawn Simmons - 답글 공유
I’m trying to find the replacement part to buy too.
Wendy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 14
전체 시간: 964
