소개
Upgrade your hard drive for more storage capacity.
필요한 것
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the following three screws:
One shouldered 12.4 mm Phillips.
Two 7 mm T10 Torx.
Remove the two 15 mm shouldered T10 Torx screws from the hard drive and remove the bracket.
다른 149명이 해당 안내서를 완성하였습니다.
