주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iMac Intel 27" EMC 2429 RAM Replacement
필요한 것
    1. iMac Intel 27" EMC 2429 RAM Replacement, Access Door: 1 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2429 RAM Replacement, Access Door: 1 단계, 이미지 2개 중 2개
      • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
      • These screws will remain captive in the access door.
      • Remove the access door from your iMac.
      • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
      댓글 쓰기
    1. iMac Intel 27" EMC 2429 RAM Replacement, RAM: 2 단계, 이미지 1개 중 1개
      • Use your fingers or the tip of a spudger to slide the black plastic RAM tray pull tab out of the RAM slot.
      댓글 쓰기
    2. iMac Intel 27" EMC 2429 RAM Replacement: 3 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2429 RAM Replacement: 3 단계, 이미지 2개 중 2개
      • Pull the black plastic tab away from the iMac to eject the RAM chip from its socket.
      • The RAM modules are firmly seated and may require a fair amount of force to remove.
      • Use your fingers to slide the RAM chip out of its socket.
      • If necessary, repeat this process for the other RAM module(s).
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 93명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Phillip Takahashi
회원 가입일: 08/22/11
87,929 평판
안내서 87개를 작성함
15가이드 댓글
My iMac 21.5-inch Mid 2011 has EMC 2428, but still directions turned out to be the same.
I replaced the memory in my MacBook Pro, and used the old cards (2x2GB) to fill out the 2 empty slots that apple left empty, doubled the memory of 2 machines for the price of one ^_^
Mabel - 답글 공유
So confused. I have an end 2429 and I ordered some memory hut its says notebook memory, do these machines use the same type of ram?
Kosta Kritikos - 답글 공유
Thanks ifixit team, I did it. It is really piece of cake! Thanks again!
prelude0214 - 답글 공유
What's the real max capacity for the RAM?
Angel Pimienta - 답글 공유
16 Gb (4 x 4 Gb) DDR3 1333 MHz
Aleksei Marinichev - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 27
지난 30일: 146
전체 시간: 88,143
