주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPad Display Assembly 4 Pc. Adhesive Application
필요한 것
    1. iPad Display Assembly 4 Pc. Adhesive Application, iPad Display Assembly 4 Pc. Adhesive Application: 1 단계, 이미지 2개 중 1개 iPad Display Assembly 4 Pc. Adhesive Application, iPad Display Assembly 4 Pc. Adhesive Application: 1 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Before installing new adhesive, thoroughly clean the display assembly and the frame of all residue.
      • Use tweezers to pull up sections of tape residue.
      • Use an opening tool or a spudger to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to soften the adhesive.
      • Remove the residue by wiping in one direction to prevent smearing.
      • Do not scrape with a metal tool, or you will scratch the display assembly's surface.
      댓글 쓰기
    2. iPad Display Assembly 4 Pc. Adhesive Application: 2 단계, 이미지 1개 중 1개
      • Lay out the replacement adhesive strips around the display assembly so that they correspond to the correct sides.
      댓글 쓰기
    3. iPad Display Assembly 4 Pc. Adhesive Application: 3 단계, 이미지 2개 중 1개 iPad Display Assembly 4 Pc. Adhesive Application: 3 단계, 이미지 2개 중 2개
      • Each adhesive strip is encased in four layers of plastic—three on top and one on the bottom.
      • Peel and remove the topmost plastic cling layer from the left adhesive strip.
      • Peel and remove the bottom plastic liner from the strip.
      • The top of the adhesive strip should still be covered by a colored plastic layer as well as a clear plastic stiffening layer.
      • The bottom of the adhesive strip should now be exposed and sticky.
      댓글 쓰기
    4. iPad Display Assembly 4 Pc. Adhesive Application: 4 단계, 이미지 2개 중 1개 iPad Display Assembly 4 Pc. Adhesive Application: 4 단계, 이미지 2개 중 2개
      • If there are extra bits of adhesive on the strips that are not required for your particular model of iPad, remove them now.
      댓글 쓰기
    5. iPad Display Assembly 4 Pc. Adhesive Application: 5 단계, 이미지 3개 중 1개 iPad Display Assembly 4 Pc. Adhesive Application: 5 단계, 이미지 3개 중 2개 iPad Display Assembly 4 Pc. Adhesive Application: 5 단계, 이미지 3개 중 3개
      • Align the left adhesive strip to the left edge of the display assembly.
      • Beginning from one corner, lay the adhesive strip onto the display assembly and press the strip into place.
      • If necessary, use a spudger to press down the narrow parts of the adhesive strip.
      댓글 쓰기
    6. iPad Display Assembly 4 Pc. Adhesive Application: 6 단계, 이미지 3개 중 1개 iPad Display Assembly 4 Pc. Adhesive Application: 6 단계, 이미지 3개 중 2개 iPad Display Assembly 4 Pc. Adhesive Application: 6 단계, 이미지 3개 중 3개
      • Repeat the process with the right adhesive strip.
      • Peel and remove the topmost cling layer from the strip.
      • Peel and remove the bottom liner layer from the strip.
      • Align the adhesive strip to the right edge of the display assembly.
      • Starting from one corner, lay the adhesive strip onto the display assembly and press in place.
      댓글 쓰기
    7. iPad Display Assembly 4 Pc. Adhesive Application: 7 단계, 이미지 3개 중 1개 iPad Display Assembly 4 Pc. Adhesive Application: 7 단계, 이미지 3개 중 2개 iPad Display Assembly 4 Pc. Adhesive Application: 7 단계, 이미지 3개 중 3개
      • Repeat the process for the top adhesive strip.
      • Peel and remove the bottom liner from the strip.
      • Align the strip to the top of the display assembly such that the straight adhesive line bridges the gap between the left and right strips.
      • Press the strip in place.
      댓글 쓰기
    8. iPad Display Assembly 4 Pc. Adhesive Application: 8 단계, 이미지 3개 중 1개 iPad Display Assembly 4 Pc. Adhesive Application: 8 단계, 이미지 3개 중 2개 iPad Display Assembly 4 Pc. Adhesive Application: 8 단계, 이미지 3개 중 3개
      • Repeat the process for the bottom adhesive strip.
      • Align the strip to the bottom of the display assembly such that the straight adhesive line bridges the gap between the left and right strips.
      댓글 쓰기
    9. iPad Display Assembly 4 Pc. Adhesive Application: 9 단계, 이미지 3개 중 1개 iPad Display Assembly 4 Pc. Adhesive Application: 9 단계, 이미지 3개 중 2개 iPad Display Assembly 4 Pc. Adhesive Application: 9 단계, 이미지 3개 중 3개
      • Peel and remove the clear plastic stiffening layer from all four adhesive strip sections.
      댓글 쓰기
    10. iPad Display Assembly 4 Pc. Adhesive Application: 10 단계, 이미지 1개 중 1개
      • Continue with the reassembly process until you are ready to seal the device.
      댓글 쓰기
    11. iPad Display Assembly 4 Pc. Adhesive Application: 11 단계, 이미지 2개 중 1개 iPad Display Assembly 4 Pc. Adhesive Application: 11 단계, 이미지 2개 중 2개
      • Peel and remove the four colored plastic liners to expose the adhesive.
      • Close the device and place something heavy, such as a stack of large books, on top for thirty minutes to help the new adhesive bond.
      • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
      댓글 쓰기
결론
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tarun Thiruma
회원 가입일: 11/20/19
40,468 평판
안내서 134개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 81
전체 시간: 3,286
