주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPad Pro 10.5" Logic Board Replacement
필요한 것
  1. iPad Pro 10.5" Logic Board Replacement, Prepare an iOpener: 1 단계, 이미지 1개 중 1개
    • Strong adhesive holds the screen in place. In order to separate it, you'll first need to heat and soften the adhesive using an iOpener, hair dryer, or heat gun.
    • You may need to reapply heat repeatedly throughout this process to prevent the adhesive from cooling and hardening.
    • Prepare an iOpener and place it on the bottom edge of the iPad's screen for about two minutes.
  2. iPad Pro 10.5" Logic Board Replacement, Create an opening gap: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • If your iPad's screen is badly cracked, wear skin and eye protection. Cover the screen with a smooth layer of clear packing tape to contain glass shards and help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
    • Place a suction cup next to the iPad's home button and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
    • If you want to use the Anti-Clamp, a tool we designed to make the opening procedure easier, follow this guide.
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Don't pull too hard, or you may shatter the glass. If necessary, apply more heat to further soften the adhesive.
    • Once you've opened a sufficient gap, insert an opening pick into the gap.
  3. iPad Pro 10.5" Logic Board Replacement, Slice through the bottom adhesive: 3 단계, 이미지 2개 중 1개 iPad Pro 10.5" Logic Board Replacement, Slice through the bottom adhesive: 3 단계, 이미지 2개 중 2개
    • Slice through the adhesive under the screen by sliding the pick along the edge of the display, towards the bottom left corner.
    • Leave the pick in place temporarily to prevent the adhesive from re-sealing.
  4. iPad Pro 10.5" Logic Board Replacement, Slice through the left adhesive: 4 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement, Slice through the left adhesive: 4 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement, Slice through the left adhesive: 4 단계, 이미지 3개 중 3개
    • Apply heat to the left edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    • If necessary, re-heat your iOpener for a few seconds or until it's a bit too hot to touch. Be careful not to overheat the iOpener, or it may burst.
    • Insert a second opening pick at the bottom left corner of the iPad.
    • Slide the second opening pick along the left side of the display to separate the adhesive underneath.
    • Leave the opening pick inserted near the top left corner of the iPad to prevent the adhesive from re-sealing.
  5. iPad Pro 10.5" Logic Board Replacement: 5 단계, 이미지 1개 중 1개
    • Apply heat to the top edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
  6. iPad Pro 10.5" Logic Board Replacement: 6 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement: 6 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement: 6 단계, 이미지 3개 중 3개
    • Insert a third opening pick at the top left corner of the iPad.
    • Use the opening pick to cut the adhesive under the top edge of the iPad by sliding it to the top right corner.
    • The front-facing camera is located right in the center of the iPad's top edge and can be damaged if the pick is inserted too far. Only insert the tip of the opening pick when cutting near the camera.
  7. iPad Pro 10.5" Logic Board Replacement: 7 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement: 7 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement: 7 단계, 이미지 3개 중 3개
    • Apply heat to the final, right edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    • Insert a fourth opening pick at the top right corner of the iPad.
    • Slide the opening pick down to the bottom right corner to cut the adhesive.
    • Slide the opening pick around the bottom right corner—pausing to apply more heat if needed—and cut the remaining adhesive on the bottom edge, but stop before you reach the home button.
  8. iPad Pro 10.5" Logic Board Replacement: 8 단계, 이미지 2개 중 1개 iPad Pro 10.5" Logic Board Replacement: 8 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick at the top of the iPad near (but not directly on) the front-facing camera.
    • Gently twist the pick to separate the display assembly from the iPad.
    • Don't try to remove the display all the way yet! It is still connected to the iPad's motherboard.
    • If needed, apply more heat and/or cut any remaining adhesive that prevents the display from separating.
  9. iPad Pro 10.5" Logic Board Replacement: 9 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement: 9 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement: 9 단계, 이미지 3개 중 3개
    • Lift the display assembly from its top edge and carefully slide it up (towards the front-facing camera and headphone jack), until the screw that secures the battery power connector is revealed at the bottom.
    • Don't lift the display more than 70° or you may damage the attached ribbon cables.
  10. iPad Pro 10.5" Logic Board Replacement: 10 단계, 이미지 2개 중 1개 iPad Pro 10.5" Logic Board Replacement: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Remove the 1.9 mm Phillips screw that secures the battery power connector.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  11. iPad Pro 10.5" Logic Board Replacement, Battery connector information: 11 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement, Battery connector information: 11 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement, Battery connector information: 11 단계, 이미지 3개 중 3개
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  12. iPad Pro 10.5" Logic Board Replacement, Disconnect the battery: 12 단계, 이미지 1개 중 1개
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • To disconnect the battery, slide one prong of a battery blocker or the tip of an opening pick under the battery power connector to ensure the power circuit is interrupted.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages.
    • Leave the battery blocker in place as you work.
  13. iPad Pro 10.5" Logic Board Replacement: 13 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement: 13 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement: 13 단계, 이미지 3개 중 3개
    • Slowly lift the display from its top edge, being careful not to strain the attached ribbon cables.
    • Remove the two 1.3 mm Phillips screws securing the display connector cover bracket.
    • You may need to angle the driver slightly in order to avoid straining the ribbon cables.
    • Remove the display connector cover bracket.
  14. iPad Pro 10.5" Logic Board Replacement: 14 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement: 14 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement: 14 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the two visible display flex connectors by gently prying them straight up from their sockets.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. iPad Pro 10.5" Logic Board Replacement: 15 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement: 15 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement: 15 단계, 이미지 3개 중 3개
    • Underneath, you'll find two additional display cable connectors.
    • Use your spudger to gently pry them up and disconnect them.
  16. iPad Pro 10.5" Logic Board Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the display assembly.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing display, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
  17. iPad Pro 10.5" Logic Board Replacement, Logic Board: 17 단계, 이미지 1개 중 1개
    • Remove the following 10 Phillips #000 screws.
    • Eight 1.3 mm screws
    • Two 2.3 mm screws
  18. iPad Pro 10.5" Logic Board Replacement: 18 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement: 18 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement: 18 단계, 이미지 3개 중 3개
    • Remove the logic board shield
  19. iPad Pro 10.5" Logic Board Replacement: 19 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement: 19 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement: 19 단계, 이미지 3개 중 3개
    • Disconnect the top left & right sensor array front panel connectors (FPC).
  20. iPad Pro 10.5" Logic Board Replacement: 20 단계, 이미지 2개 중 1개 iPad Pro 10.5" Logic Board Replacement: 20 단계, 이미지 2개 중 2개
    • Disconnect the front camera FPC's.
  21. iPad Pro 10.5" Logic Board Replacement: 21 단계, 이미지 2개 중 1개 iPad Pro 10.5" Logic Board Replacement: 21 단계, 이미지 2개 중 2개
    • Disconnect the keyboard adapter FPC
  22. iPad Pro 10.5" Logic Board Replacement: 22 단계, 이미지 2개 중 1개 iPad Pro 10.5" Logic Board Replacement: 22 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to disconnect the antenna connectors.
    • Be sure to grab the cable by the metal shielding on the connector and pull straight up.
  23. iPad Pro 10.5" Logic Board Replacement: 23 단계, 이미지 2개 중 1개 iPad Pro 10.5" Logic Board Replacement: 23 단계, 이미지 2개 중 2개
    • Gently pull up on the antenna coax cable to separate it from the logic board.
  24. iPad Pro 10.5" Logic Board Replacement: 24 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement: 24 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement: 24 단계, 이미지 3개 중 3개
    • Pull back on the tape covering the speaker FPC and disconnect the FPC.
  25. iPad Pro 10.5" Logic Board Replacement: 25 단계, 이미지 1개 중 1개
    • Repeat for the other speaker FPC
  26. iPad Pro 10.5" Logic Board Replacement, Lightning Connector: 26 단계, 이미지 1개 중 1개
    • Remove the following Phillips #000 screws.
    • Two 2.4 mm screws
    • Two 1.7 mm screws
  27. iPad Pro 10.5" Logic Board Replacement: 27 단계, 이미지 1개 중 1개
    • Heat the back of the iPad to loosen the adhesive holding the logic board to the housing.
    • Optionally, you can use adhesive remover, such as acetone, to help loosen the adhesive. Be cautious to not get too much under the battery, as this can unintentionally weaken the battery adhesive.
  28. iPad Pro 10.5" Logic Board Replacement: 28 단계, 이미지 3개 중 1개 iPad Pro 10.5" Logic Board Replacement: 28 단계, 이미지 3개 중 2개 iPad Pro 10.5" Logic Board Replacement: 28 단계, 이미지 3개 중 3개
    • Carefully pry near the top of the logic board to release the adhesive.
    • Make certain that all of the connectors clear the logic board as you remove it.
    • Pull logic board with the lightning connector away from the main housing.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
iHelpU.Tech
회원 가입일: 08/02/17
4,050 평판
안내서 5개를 작성함
iHelpU.tech iHelpU.tech 회원
Business
2 회원들
안내서 17개를 작성함
3가이드 댓글
On the cellular model be sure to disconnect the two antenna up by the front facing camera on the board as well as the sim card reader connector by the battery connector.
Chris - 답글 공유
Just wanted to share that an easier route is to use an eBay iPad logic board service. You mail your iPad in and they fix and return ship. I have availed services from two sellers for my iPad pro 10.5, once to replace the charging port and a second time when something shorted out on the logic board. Local repair shops can plug in a little tester into the lightening port to test whether it’s a broken connector, burned out tristar power IC or something else shorted out. Depending on where you live, it may be cheaper to just mail in to eBay sellers. Depending on the issue, it can be around ~$100 total to just replace a connector or shorted component, including mailing costs.
AGhosh - 답글 공유
Can you replace the logic board w/an (upgrade)A12 chip logic board?
Im broke musician desperate for midi functions & logic plz and ThaNk yOu
Dj Microdot - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 43
지난 30일: 166
전체 시간: 14,214
