주요 콘텐츠로 건너뛰기
iPhone 13 No Power Easy Solution
필요한 것
  1. iPhone 13 No Power Easy Solution, Check the iPhone 13 on DC Power: 1 단계, 이미지 1개 중 1개
    • Prompt to boot and we see that the current jumps to 1.9 AMPs and hangs out.
    • That is a short circuit.
  2. iPhone 13 No Power Easy Solution, Diode mode to find the shorted line: 2 단계, 이미지 1개 중 1개
    • Diode mode around (red probe on ground) to find the line that is short.
    • Don't fall in love with the cap that you find that shows you the shorted line. It doesn't mean that it is the cause of the shorted line, though it could be.
    • If the line is short anywhere, the line is short everywhere.
  3. iPhone 13 No Power Easy Solution, Determine the line with the short: 3 단계, 이미지 1개 중 1개
    • This line is short, it looks alot like our 3PV0 Nand Power line that drives power for the Nand chip in every phone.
    • That is a common line for shorts.
    • Now determine which of these components on the line are the cause of the short.
  4. iPhone 13 No Power Easy Solution, Check with thermal cam: 4 단계, 이미지 1개 중 1개
    • Connect with DC power (make note of the connector direction for the 13 on the squid)
    • Prompt to boot and look for heat near the NAND chip.
    • That cap is the cause of the short.
  5. iPhone 13 No Power Easy Solution, Remove the shorted component: 5 단계, 이미지 1개 중 1개
    • Remove the black coating from the shorted cap.
    • Check the measurement, it is indeed measuring low resistance to ground.
    • Safest way to remove this cap is to use the iPad Rehab Short Killer and pop that cap off.
    • Check the line to make sure the short was removed.
  6. iPhone 13 No Power Easy Solution, Prompt to boot and SUCCESS!!: 6 단계, 이미지 2개 중 1개 iPhone 13 No Power Easy Solution, Prompt to boot and SUCCESS!!: 6 단계, 이미지 2개 중 2개
    • Prompt to boot.
    • DC power looks normal, screen boots with touch.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
jessabethany
회원 가입일: 12/02/13
30,737 평판
안내서 1개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,697개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 56
지난 30일: 227
전체 시간: 6,239
