주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
해당 분해도는 수리 안내서가 아닙니다. iPhone 13 Pro 수리는 자사의 서비스 설명서를 사용하세요.
    1. iPhone 13 Pro Full Chip ID, iPhone 13 Pro Full Chip ID: 1 단계, 이미지 1개 중 1개
      • Logic board, side 1:
      • Apple APL1W07 A15 Bionic SoC layered with what's most likely 6 GB of SK Hynix LPDDR4X SDRAM
      • Apple APL1098 power management IC
      • Apple 338S00762-A1 power management IC
      • STMicroelectronics STB601A05 power management IC
      • Apple 338S00770-B0 power management IC
      • Texas Instruments TPS65657B0 display power management IC
      • NXP Semiconductor CBTL1616A0 display port multiplexer
      댓글 쓰기
    2. iPhone 13 Pro Full Chip ID: 2 단계, 이미지 1개 중 1개
      • Logic board, side 1 (cont.):
      • Texas Instruments CD3710A1 VCSEL array driver
      • Texas Instruments USB 2.0 dual repeater
      • ON Semiconductor DC-DC converter
      • Possibly a NXP Semiconductor power management IC
      • Possibly a NXP Semiconductor load switch
      댓글 쓰기
    3. iPhone 13 Pro Full Chip ID: 3 단계, 이미지 1개 중 1개
      • Apple/USI U1 ultra-wideband chip
      • Skyworks SKY58271-19 front-end module
      • Skyworks SKY58276-17 front-end module
      • Likely a Broadcom AFEM-8225 front-end module
      • Likely a Skyworks SKY59723 power amplifier module
      • Likely a Murata 141 RF switch module
      • Likely Broadcom filters
      댓글 쓰기
    4. iPhone 13 Pro Full Chip ID: 4 단계, 이미지 1개 중 1개
      • Alps HSCDTD00xA electronic compass
      댓글 쓰기
    5. iPhone 13 Pro Full Chip ID: 5 단계, 이미지 1개 중 1개
      • Logic board, sides 2 and 3:
      • 128 GB of Kioxia NAND flash memory
      • STMicroelectronics ST33Jxxx secure microcontroller w/ eSIM
      • Possibly an Apple/Cirrus Logic 338S00817 audio processor
      • Apple/Cirrus Logic 338S00739 audio codec
      • Apple/Cirrus Logic 338S00537 audio amplifier
      • Broadcom BCM59365 wireless power receiver
      • Likely an Analog Devices haptic driver
      댓글 쓰기
    6. iPhone 13 Pro Full Chip ID: 6 단계, 이미지 1개 중 1개
      • Logic board, sides 2 and 3 (cont.):
      • Qualcomm PMX60 power management IC
      • Apple 338S00616 power management IC
      • Texas Instruments LM3567A1 LED flash driver
      • Likely a STMicroelectronics DC-DC converter
      • Nexperia 74AVC1T45 3-state voltage level translator/transceiver
      • Nexperia LSF0101 1-bit bidirectional voltage level translator
      댓글 쓰기
    7. iPhone 13 Pro Full Chip ID: 7 단계, 이미지 1개 중 1개
      • USI 339S00761 WiFi/Bluetooth module
      • Qualcomm SDX60M 5G modem
      • Possibly a Qualcomm SDR868 5G RF transceiver
      • Broadcom AFEM-8215 front-end module
      • Possibly a Skyworks SKY53838-17 front-end module
      • NXP Semiconductor SN210V NFC controller with secure element
      • Likely a Skyworks SKY57217 power amplifier module
      댓글 쓰기
    8. iPhone 13 Pro Full Chip ID: 8 단계, 이미지 1개 중 1개
      • Qualcomm QET510 envelope tracker
      • Qualcomm QET5100 envelope tracker
      • Likely a Qorvo envelope tracker
      • Likely a Skyworks SKY514xx RF switch module
      • Likely Skyworks RF switch
      • Likely Murata antenna switch module
      • Antenna tuning switch
      댓글 쓰기
    9. iPhone 13 Pro Full Chip ID: 9 단계, 이미지 1개 중 1개
      • Bosch Sensortec 6-axis accelerometer/gyroscope
      댓글 쓰기
작성자
3다른 기여자 명과 함께
Craig Lloyd
회원 가입일: 02/10/16
42,978 평판
안내서 82개를 작성함
9가이드 댓글
Which one is the wifi/bt chip?
u2f u2f - 답글 공유
Refer to Step 7,
There is no WiFi/BT chip on the main board. Instead, Apple uses USI 339S00761 WiFi/Bluetooth module .
JJ Wu - 답글 공유
Is barometer still Bosch’s solution?
JJ Wu - 답글 공유
Does anyone know anything more about the USI 339S00761 WiFi/Bluetooth module? Specifically, it would be really interesting to understand if there is Bluetooth LE Audio capabilities hidden there.
Gustaf Rosell - 답글 공유
please i need a help my iphone 13 pro i try to restore and gave me error unable to restore idevice (-1)
izeko mobile - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 36
지난 7일: 142
지난 30일: 707
전체 시간: 67,796
