주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 13 Pro Screen Replacement
  1. iPhone 13 Pro Screen Replacement, Remove the pentalobe screws: 1 단계, 이미지 1개 중 1개
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    댓글 쓰기
  2. iPhone 13 Pro Screen Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 iPhone 13 Pro Screen Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 iPhone 13 Pro Screen Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
    댓글 쓰기
  3. iPhone 13 Pro Screen Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 1개 iPhone 13 Pro Screen Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 2개 iPhone 13 Pro Screen Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 3개
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Aristotelis Pantos
회원 가입일: 01/25/25
153 평판
안내서 1개를 작성함
1가이드 댓글
I want tools
Lil Vhim - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 89
지난 30일: 452
전체 시간: 2,899
