주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 16 Pro Back Glass Removal
단지 전제 조건
이 가이드는 전제 조건만을 다룹니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. iPhone 16 Pro Back Glass Removal, Prepare the phone for disassembly: 1 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Prepare the phone for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
  2. iPhone 16 Pro Back Glass Removal, Tape over any cracks: 2 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Tape over any cracks: 2 단계, 이미지 2개 중 2개
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Back Glass Removal, Mark your opening picks: 3 단계, 이미지 3개 중 1개 iPhone 16 Pro Back Glass Removal, Mark your opening picks: 3 단계, 이미지 3개 중 2개 iPhone 16 Pro Back Glass Removal, Mark your opening picks: 3 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro Back Glass Removal, Remove the pentalobe screws: 4 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Remove the pentalobe screws: 4 단계, 이미지 2개 중 2개
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro Back Glass Removal, Heat the bottom edge: 5 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Heat the bottom edge: 5 단계, 이미지 2개 중 2개
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 16 Pro Back Glass Removal, Insert an opening pick: 6 단계, 이미지 3개 중 1개 iPhone 16 Pro Back Glass Removal, Insert an opening pick: 6 단계, 이미지 3개 중 2개 iPhone 16 Pro Back Glass Removal, Insert an opening pick: 6 단계, 이미지 3개 중 3개
    • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro Back Glass Removal, Back glass information: 7 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Back glass information: 7 단계, 이미지 2개 중 2개
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    • If you damage the spring contacts, gently bend them back with a spudger or opening pick so they align with their gold contact pads on the back glass.
  8. iPhone 16 Pro Back Glass Removal, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 1개 iPhone 16 Pro Back Glass Removal, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 2개 iPhone 16 Pro Back Glass Removal, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 3개
    • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contact.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro Back Glass Removal, Heat the right edge: 9 단계, 이미지 1개 중 1개
    • Heat the right edge of the back glass until it's hot to the touch.
  10. iPhone 16 Pro Back Glass Removal, Separate the bottom right corner adhesive: 10 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Separate the bottom right corner adhesive: 10 단계, 이미지 2개 중 2개
    • Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 16 Pro Back Glass Removal, Heat the left edge: 11 단계, 이미지 1개 중 1개
    • Heat the left edge of the back glass until it's hot to the touch.
  12. iPhone 16 Pro Back Glass Removal, Separate the left edge adhesive: 12 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Separate the left edge adhesive: 12 단계, 이미지 2개 중 2개
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  13. iPhone 16 Pro Back Glass Removal, Heat the top edge: 13 단계, 이미지 1개 중 1개
    • Heat the top edge of the back glass, including the area around the volume buttons, until it's hot to the touch.
  14. iPhone 16 Pro Back Glass Removal, Separate the top edge adhesive: 14 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Separate the top edge adhesive: 14 단계, 이미지 2개 중 2개
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
    • You'll hear and feel clicks as the top two clips release.
  15. iPhone 16 Pro Back Glass Removal, Swing open the back glass: 15 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Swing open the back glass: 15 단계, 이미지 2개 중 2개
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
    • Gently swing open the back glass towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    • Remove the opening picks.
    • Consider using polyimide tape to protect the rear camera lenses while you're working inside the phone. Don't push against the lenses to avoid damaging the delicate stabilizers.
  16. iPhone 16 Pro Back Glass Removal, Disconnect the battery: 16 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Disconnect the battery: 16 단계, 이미지 2개 중 2개
    • Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
    • Two 1.2 mm‑long screws
    • One 1.0 mm‑long screw
  17. iPhone 16 Pro Back Glass Removal: 17 단계, 이미지 3개 중 1개 iPhone 16 Pro Back Glass Removal: 17 단계, 이미지 3개 중 2개 iPhone 16 Pro Back Glass Removal: 17 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to pick up and remove the lower connector cover.
  18. iPhone 16 Pro Back Glass Removal: 18 단계, 이미지 3개 중 1개 iPhone 16 Pro Back Glass Removal: 18 단계, 이미지 3개 중 2개 iPhone 16 Pro Back Glass Removal: 18 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  19. iPhone 16 Pro Back Glass Removal, Disconnect the back glass: 19 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Disconnect the back glass: 19 단계, 이미지 2개 중 2개
    • Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
    • Two 1.0 mm‑long screws
    • One 1.2 mm‑long screw
    • One 1.6 mm‑long screw
  20. iPhone 16 Pro Back Glass Removal: 20 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal: 20 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to pick up and remove the upper connector cover.
  21. iPhone 16 Pro Back Glass Removal: 21 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal: 21 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the back glass press connector.
  22. iPhone 16 Pro Back Glass Removal, Remove the back glass: 22 단계, 이미지 2개 중 1개 iPhone 16 Pro Back Glass Removal, Remove the back glass: 22 단계, 이미지 2개 중 2개
    • Lift the back glass off the frame and remove it.
결론
To reassemble your iPhone, follow this guide to reapply adhesive and install your back glass.
After your repair, calibrate a genuine replacement back glass using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers Community for help.
Nick Schultz
회원 가입일: 03/24/24
53,264 평판
안내서 300개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,587개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 8
전체 시간: 153
