주요 콘텐츠로 건너뛰기
iPhone 16 Pro Screen Removal
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. iPhone 16 Pro Screen Removal, Prepare the phone for disassembly: 1 단계, 이미지 2개 중 1개 iPhone 16 Pro Screen Removal, Prepare the phone for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
  2. iPhone 16 Pro Screen Removal, Tape over any cracks: 2 단계, 이미지 2개 중 1개 iPhone 16 Pro Screen Removal, Tape over any cracks: 2 단계, 이미지 2개 중 2개
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Screen Removal, Mark your opening picks: 3 단계, 이미지 3개 중 1개 iPhone 16 Pro Screen Removal, Mark your opening picks: 3 단계, 이미지 3개 중 2개 iPhone 16 Pro Screen Removal, Mark your opening picks: 3 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro Screen Removal, Remove the pentalobe screws: 4 단계, 이미지 2개 중 1개 iPhone 16 Pro Screen Removal, Remove the pentalobe screws: 4 단계, 이미지 2개 중 2개
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro Screen Removal, Create a gap with a suction handle: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iOpener
    $14.99
    • The next two steps show how to create an initial gap using a suction handle.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • You can also use an iOpener to heat the screen. Follow these instructions to heat and apply the iOpener properly.
  6. iPhone 16 Pro Screen Removal: 6 단계, 이미지 3개 중 1개 iPhone 16 Pro Screen Removal: 6 단계, 이미지 3개 중 2개 iPhone 16 Pro Screen Removal: 6 단계, 이미지 3개 중 3개
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • If you can't create a gap, apply more heat to the edge and try again.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro Screen Removal, Screen information: 7 단계, 이미지 1개 중 1개
    • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • Two delicate cables connecting the screen to the iPhone—one just above the Action button and the other about halfway along the left edge of the iPhone
    • Multiple spring contacts around the perimeter of the iPhone
  8. iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: 8 단계, 이미지 3개 중 1개 iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: 8 단계, 이미지 3개 중 2개 iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: 8 단계, 이미지 3개 중 3개
    • Slide the opening pick along the bottom edge to release the adhesive.
    • Don't insert the pick deeper than 3 mm to avoid damaging the spring contacts.
    • If the adhesive feels difficult to slice, reheat the edge for a minute.
    • Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro Screen Removal, Heat the left edge: 9 단계, 이미지 1개 중 1개
    • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
  10. iPhone 16 Pro Screen Removal, Separate the left adhesive: 10 단계, 이미지 2개 중 1개 iPhone 16 Pro Screen Removal, Separate the left adhesive: 10 단계, 이미지 2개 중 2개
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts and cables.
    • Insert a second opening pick in the bottom-left corner, close to the existing pick.
    • Slide the opening pick along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave the opening pick in the top-left corner to prevent the adhesive from resealing.
  11. iPhone 16 Pro Screen Removal, Separate the remaining adhesives: 11 단계, 이미지 3개 중 1개 iPhone 16 Pro Screen Removal, Separate the remaining adhesives: 11 단계, 이미지 3개 중 2개 iPhone 16 Pro Screen Removal, Separate the remaining adhesives: 11 단계, 이미지 3개 중 3개
    • Repeat the heating and slicing procedure along the remaining screen edges.
  12. iPhone 16 Pro Screen Removal, Swing open the screen: 12 단계, 이미지 3개 중 1개 iPhone 16 Pro Screen Removal, Swing open the screen: 12 단계, 이미지 3개 중 2개 iPhone 16 Pro Screen Removal, Swing open the screen: 12 단계, 이미지 3개 중 3개
    • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick and carefully check for missed sections of adhesive or stuck clips.
    • Carefully lift the screen upwards until the clips along the long edges clear the frame.
    • Swing open the screen over the left edge of the iPhone and lay it flat on your work surface.
  13. iPhone 16 Pro Screen Removal, Remove the connector covers: 13 단계, 이미지 1개 중 1개
    • Use a tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the front sensor and display connector covers.
  14. iPhone 16 Pro Screen Removal: 14 단계, 이미지 3개 중 1개 iPhone 16 Pro Screen Removal: 14 단계, 이미지 3개 중 2개 iPhone 16 Pro Screen Removal: 14 단계, 이미지 3개 중 3개
    • Use tweezers to grasp the front sensor connector cover near the screw hole.
    • Lift and remove the cover.
  15. iPhone 16 Pro Screen Removal: 15 단계, 이미지 3개 중 1개 iPhone 16 Pro Screen Removal: 15 단계, 이미지 3개 중 2개 iPhone 16 Pro Screen Removal: 15 단계, 이미지 3개 중 3개
    • Repeat this process for the other cover.
  16. iPhone 16 Pro Screen Removal, Disconnect the screen: 16 단계, 이미지 2개 중 1개 iPhone 16 Pro Screen Removal, Disconnect the screen: 16 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the display press connector.
  17. iPhone 16 Pro Screen Removal: 17 단계, 이미지 2개 중 1개 iPhone 16 Pro Screen Removal: 17 단계, 이미지 2개 중 2개
    • Repeat this process for the front sensor press connector.
  18. iPhone 16 Pro Screen Removal, Remove the screen: 18 단계, 이미지 1개 중 1개
    • Remove the screen.
결론
To reassemble your iPhone, follow these instructions in reverse order.
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
Nick Schultz
회원 가입일: 03/24/24
37,410 평판
안내서 226개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,758개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 838
