주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 3G Camera Replacement
필요한 것
    1. iPhone 3G Camera Replacement, Broken Glass: 1 단계, 이미지 3개 중 1개 iPhone 3G Camera Replacement, Broken Glass: 1 단계, 이미지 3개 중 2개 iPhone 3G Camera Replacement, Broken Glass: 1 단계, 이미지 3개 중 3개
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      댓글 쓰기
    1. iPhone 3G Camera Replacement, Camera: 2 단계, 이미지 1개 중 1개
      • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
      댓글 쓰기
    2. iPhone 3G Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
      • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
      • Be very careful when opening the iPhone so that the cables under the display are not severed.
      • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
      • If the display assembly is to damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape maybe used.
      댓글 쓰기
    3. iPhone 3G Camera Replacement: 4 단계, 이미지 1개 중 1개
      • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
      • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
      댓글 쓰기
    4. iPhone 3G Camera Replacement: 5 단계, 이미지 1개 중 1개
      • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
      댓글 쓰기
    5. iPhone 3G Camera Replacement: 6 단계, 이미지 1개 중 1개
      • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
      • Use a spudger to disconnect the black ribbon cable labeled "2."
      댓글 쓰기
    6. iPhone 3G Camera Replacement: 7 단계, 이미지 1개 중 1개
      • Ribbon cable "3" is held in place by an FPC style connector. Unlocking this connector is a must before removing the ribbon cable: use a plastic spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
      • Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
      댓글 쓰기
    7. iPhone 3G Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
      • Press down on the tool until the SIM card tray pops out.
      • Grasp the SIM card tray and slide it out of the iPhone.
      댓글 쓰기
    8. iPhone 3G Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Use a spudger to disconnect the ribbon cable labeled "4."
      댓글 쓰기
    9. iPhone 3G Camera Replacement: 10 단계, 이미지 1개 중 1개
      • Use a spudger to disconnect the ribbon cable labeled "5."
      댓글 쓰기
    10. iPhone 3G Camera Replacement: 11 단계, 이미지 2개 중 1개 iPhone 3G Camera Replacement: 11 단계, 이미지 2개 중 2개
      • Use a spudger to disconnect the ribbon cable labeled "6."
      • If you have an iPhone 3GS, refer to picture 2 and use a spudger to disconnect the ribbon cable labeled "7."
      댓글 쓰기
    11. iPhone 3G Camera Replacement: 12 단계, 이미지 1개 중 1개
      • Carefully peel up the small sticker labeled "Do not remove."
      댓글 쓰기
    12. iPhone 3G Camera Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the following 8 screws:
      • Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
      • Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
      • One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
      댓글 쓰기
    13. iPhone 3G Camera Replacement: 14 단계, 이미지 1개 중 1개
      • Use a spudger to gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board.
      댓글 쓰기
    14. iPhone 3G Camera Replacement: 15 단계, 이미지 1개 중 1개
      • Use a spudger to gently pry up the end of the logic board closest to the dock connector.
      • If the board won't lift up, double check to make sure all the screws securing the logic board have been removed.
      댓글 쓰기
    15. iPhone 3G Camera Replacement: 16 단계, 이미지 1개 중 1개
      • Slide the logic board towards the dock connector and out of the iPhone.
      댓글 쓰기
    16. iPhone 3G Camera Replacement: 17 단계, 이미지 1개 중 1개
      • Use a spudger to disconnect the camera from the logic board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 65명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
1가이드 댓글
Thanks for an awesome guide. On mine after getting it reassembled the camera had a green screen. The cable for the camera got slightly disconnected while putting things back together. I'm thinking because the one I got the ribbon was kinda stiff and straight when it had to fold to go back in properly it came slightly unplugged. I just squashed around the camera corner of the case pinching it, of course not to hard, and it came up and works perfectly now. Thanks again, my friend sold me this iphone cheap cause the camera was broke. Thanks to you its good as new.
Eric - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 68
전체 시간: 126,188
