주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 3G Display Assembly Replacement
필요한 것
동영상 개요
  1. iPhone 3G Display Assembly Replacement, Broken Glass: 1 단계, 이미지 3개 중 1개 iPhone 3G Display Assembly Replacement, Broken Glass: 1 단계, 이미지 3개 중 2개 iPhone 3G Display Assembly Replacement, Broken Glass: 1 단계, 이미지 3개 중 3개
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    댓글 쓰기
  2. iPhone 3G Display Assembly Replacement, Display Assembly: 2 단계, 이미지 1개 중 1개
    • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
    댓글 쓰기
  3. iPhone 3G Display Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
    • Be very careful when opening the iPhone so that the cables under the display are not severed.
    • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
    • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
    • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
    댓글 쓰기
  4. iPhone 3G Display Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
    • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
    댓글 쓰기
  5. iPhone 3G Display Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
    댓글 쓰기
  6. iPhone 3G Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
    • Use a spudger to disconnect the black ribbon cable labeled "2."
    댓글 쓰기
  7. iPhone 3G Display Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
    • The tab is very fragile, so be careful when flipping it up to unlock the cable and down to lock the cable.
    • The plastic tab may be white (instead of black) on some iPhone models.
    • Slide the ribbon cable out of its connector, and remove the display assembly from the iPhone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 229명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
steve
6,690 평판
안내서 1개를 작성함
1가이드 댓글
i went through the whole process, but my home button does not work anymore. it was fine when I started - its it possible, that one ribbon is not fully attached ore is there any other solution? Thanks for any advice!
Jakob
JakobBartke - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 94
전체 시간: 305,348
