주요 콘텐츠로 건너뛰기
iPhone 4S Power and Sensor Cable Replacement
필요한 것
  1. iPhone 4S Power and Sensor Cable Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
    • Be sure the driver is well-seated when removing Pentalobe screws—they are easy to strip.
  2. iPhone 4S Power and Sensor Cable Replacement: 2 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 2 단계, 이미지 2개 중 2개
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4S Power and Sensor Cable Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
    • Remove the rear panel from the iPhone.
  4. iPhone 4S Power and Sensor Cable Replacement, Battery: 4 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Remove the following screws securing the battery connector to the logic board:
    • One 1.7 mm Phillips screw (PH00)
    • One 1.5 mm Phillips screw (PH00)
  5. iPhone 4S Power and Sensor Cable Replacement: 5 단계, 이미지 3개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 5 단계, 이미지 3개 중 2개 iPhone 4S Power and Sensor Cable Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully push the pressure contact away from the battery connector until it slides free from its position.
    • Remove the pressure contact.
  6. iPhone 4S Power and Sensor Cable Replacement: 6 단계, 이미지 3개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 6 단계, 이미지 3개 중 2개 iPhone 4S Power and Sensor Cable Replacement: 6 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to gently pry up the battery connector from its socket on the logic board.
    • Place the tip of the tool between the loudspeaker enclosure and the metal cover of the connector, and lift the bottom edge of the connector first.
    • The battery connector comes off vertically from the logic board. Do not apply force sideways.
    • Be careful not to pry at the battery connector socket itself, or it may detach from the logic board. There are four very small solder points awaiting this mistake!
  7. iPhone 4S Power and Sensor Cable Replacement, Reassembly tip: 7 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement, Reassembly tip: 7 단계, 이미지 2개 중 2개
    • During reassembly, be sure to carefully position the pressure contact back in place. It should rest on top of the Philips screw post shown, and the gold contact should point towards the battery connector.
    • Be sure to clean the pressure contact with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
  8. iPhone 4S Power and Sensor Cable Replacement: 8 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 8 단계, 이미지 2개 중 2개
    • Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone.
    • Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
    • If the adhesive is too strong, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery.
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use the flat end of a plastic opening tool to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
  9. iPhone 4S Power and Sensor Cable Replacement: 9 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 9 단계, 이미지 2개 중 2개
    • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
    • Be careful not to pull the plastic pull tab too hard as it can be ripped off very easily.
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the ribbon cable.
    • If your replacement battery came with an uncreased cable, carefully crease the cable into the proper shape before installing the battery into the phone.
    • While installing the replacement battery, temporarily connect the battery connector to the phone to ensure proper alignment. Once the battery is glued in place, disconnect the battery connector.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  10. iPhone 4S Power and Sensor Cable Replacement, Dock Connector Cable: 10 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement, Dock Connector Cable: 10 단계, 이미지 2개 중 2개
    • Remove the following screws securing the dock connector cable cover to the logic board:
    • One 1.2 mm Phillips screw
    • Remove the metal dock connector cable cover.
  11. iPhone 4S Power and Sensor Cable Replacement: 11 단계, 이미지 1개 중 1개
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  12. iPhone 4S Power and Sensor Cable Replacement: 12 단계, 이미지 1개 중 1개
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  13. iPhone 4S Power and Sensor Cable Replacement: 13 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 13 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
  14. iPhone 4S Power and Sensor Cable Replacement, Rear Camera: 14 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Be wary of the outer plastic ring located on top of the rear camera's flash assembly. It can be easily displaced if not removed during disassembly.
    • You can use tweezers, a plastic opening tool, or a spudger to remove the outer plastic ring.
  15. iPhone 4S Power and Sensor Cable Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the following four screws securing the cable cover to the logic board:
    • One 2.7 mm Phillips screw
    • One 2.6 mm Phillips screw
    • One 1.3 mm Phillips screw
  16. iPhone 4S Power and Sensor Cable Replacement: 16 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 16 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to pry the cable cover tabs out of their slots cut into the EMI shield on the logic board.
    • Lift the cable cover from its edge nearest the top and remove it from the iPhone.
  17. iPhone 4S Power and Sensor Cable Replacement: 17 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 17 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
    • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
    • Remove the rear camera from the iPhone.
    • There is a small rubber gasket that sits underneath the rear-facing camera. Make sure that it is properly seated before reassembly.
  18. iPhone 4S Power and Sensor Cable Replacement, SIM Card: 18 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement, SIM Card: 18 단계, 이미지 2개 중 2개
    • Use a SIM eject tool or a paperclip to eject the SIM and its tray.
    • This may require a significant amount of force.
    • Remove the SIM and its tray.
  19. iPhone 4S Power and Sensor Cable Replacement, Logic Board: 19 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement, Logic Board: 19 단계, 이미지 2개 중 2개
    • Remove the five cables near the top of the logic board in the following order:
    • Headphone jack/volume button cable
    • Front facing camera cable
    • Digitizer cable
    • Display data cable
    • Power button cable (located underneath the headphone jack/volume button cable as shown in the second picture.)
    • To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
    • Be careful not to break any of the small and delicate surface mount components as you disconnect the cables.
  20. iPhone 4S Power and Sensor Cable Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the 1.5 mm Phillips screw securing the grounding clip to the logic board near the headphone jack.
  21. iPhone 4S Power and Sensor Cable Replacement: 21 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 21 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry the small grounding clip up off the logic board.
    • Carefully grasp the grounding clip and remove it from the iPhone.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the grounding clip (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
  22. iPhone 4S Power and Sensor Cable Replacement: 22 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the 4.8 mm standoff screw near the headphone jack.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  23. iPhone 4S Power and Sensor Cable Replacement: 23 단계, 이미지 1개 중 1개
    • Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna from the logic board.
  24. iPhone 4S Power and Sensor Cable Replacement: 24 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 24 단계, 이미지 2개 중 2개
    • If present, peel the piece of black tape covering the hidden screw near the power button.
    • Remove the 2.6 mm Phillips screw securing the logic board near the power button.
    • (Use caution when removing this screw and removing the power contact held by it; the contact tab will come loose with the screw)
    • Notice the small rubber bumper under the screen & digitizer cables (which are detached at top above the Q-code). This bumper can fall off of the logic board when removed or get stuck to the cables and fall off later.
  25. iPhone 4S Power and Sensor Cable Replacement: 25 단계, 이미지 1개 중 1개
    • Remove the following screws securing the logic board to the case:
    • One 2.5 mm Phillips screw near the vibrator motor
    • One 2.4 mm Phillips screw
    • One 3.6 mm standoff along the side of the logic board nearest the battery opening.
    • Use a standoff driver bit and driver handle to remove the single 3.6 mm standoff screw.
  26. iPhone 4S Power and Sensor Cable Replacement: 26 단계, 이미지 1개 중 1개
    • Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
    • Remove the logic board.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the logic board (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
    • There is a small rubber bumper that sits on the top edge of the logic board where the digitizer and screen cables come through the case. It protects the cables as they bend over the top of the logic board. This can either get stuck to the cables or fall off the logic board when it comes out. Look back over step 22 for more details.
  27. iPhone 4S Power and Sensor Cable Replacement: 27 단계, 이미지 1개 중 1개
    • Be sure not to lose the small grounding finger for the rear facing camera near the power button. This finger rests on top of the PCB, screwed down, and covered with the adhesive black plastic tape.
  28. iPhone 4S Power and Sensor Cable Replacement, Front Facing Camera: 28 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement, Front Facing Camera: 28 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to carefully pry the metal front facing camera retainer away from the case of your iPhone.
    • Remove the front facing camera retainer.
  29. iPhone 4S Power and Sensor Cable Replacement: 29 단계, 이미지 1개 중 1개
    • Remove the front facing camera.
  30. iPhone 4S Power and Sensor Cable Replacement, Power Button: 30 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement, Power Button: 30 단계, 이미지 2개 중 2개
    • Remove the two 1.6 mm Phillips screws securing the power button bracket to the outer case.
    • Take extra care with the display cables, which can prevent easy access to the right-hand screw. The cables are easily damaged.
    • Slightly pull the power button bracket away from the outer case.
  31. iPhone 4S Power and Sensor Cable Replacement: 31 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 31 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the power button from the iPhone.
    • During reassembly, take note of the correct orientation of the power button. The metal loop should be facing downwards and the outward edges should be on top.
  32. iPhone 4S Power and Sensor Cable Replacement, Power and Sensor Cable Assembly: 32 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement, Power and Sensor Cable Assembly: 32 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the edge of a plastic opening tool to pry the earpiece speaker off the adhesive securing it to the outer case. Note that the power button cable is glued to the the case as well, and will need to be pried up.
    • Use a pair of tweezers to unfold the earpiece speaker from its recess in the outer case.
    • Be careful not to tear the cable from the earpiece speaker. They are adhered together, and the cable is very delicate.
  33. iPhone 4S Power and Sensor Cable Replacement: 33 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 33 단계, 이미지 2개 중 2개
    • Use the edge of plastic opening tool to gently move the top sensor assembly away from the outer case.
    • Gently pry the top sensor assembly off the outer case.
  34. iPhone 4S Power and Sensor Cable Replacement: 34 단계, 이미지 3개 중 1개 iPhone 4S Power and Sensor Cable Replacement: 34 단계, 이미지 3개 중 2개 iPhone 4S Power and Sensor Cable Replacement: 34 단계, 이미지 3개 중 3개
    • Lift and remove the power and sensor cable assembly from the iPhone.
    • Be sure not to lose the small retainer clip located on the top sensor assembly.
  35. iPhone 4S Power and Sensor Cable Replacement, Earpiece Speaker Assembly: 35 단계, 이미지 2개 중 1개 iPhone 4S Power and Sensor Cable Replacement, Earpiece Speaker Assembly: 35 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to peel the earpiece speaker off the foam adhesive securing it to the iPhone.
    • If you wish to reuse the earpiece speaker, try not to tear the foam adhesive that secures it to the iPhone's case.
    • Remove the earpiece speaker.
  36. iPhone 4S Power and Sensor Cable Replacement, Power and Sensor Cable: 36 단계, 이미지 1개 중 1개
    • Use the edge of a plastic opening tool to separate the power button contact from its plastic bracket.
  37. iPhone 4S Power and Sensor Cable Replacement: 37 단계, 이미지 1개 중 1개
    • Power and sensor cable remains.
결론
다른 532명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Walter Galan
706,361 평판
안내서 1,203개를 작성함
20가이드 댓글
The #00 Phillips and 2.5 mm flat head screwdrivers that are suggested tools are too big. I needed to use a #000 Phillips and 5/64 in flat head screwdrivers.
Brian Clark - 답글
Difficulty: MODERATE? Then why is the vibrator replacement guide DIFFICULT? I think these need to be switch around guys...
sgreffe - 답글
This repair will destroy your soul. I would not recommend even attempting it without even more specialized tools (eye loupe, headlamp, preternatural patience) as it is extraordinarily easy to ruin your phone with one quick misstep. I've thrown in the towel after weeks of attempting the job. After ripping the screen cable for the second and final time, I'm selling for parts.
mikemckinnon - 답글
i did the repair, and my power button is now working, however the loudspeaker is now very pour and i have a lot of noise on then screen when i make a cal, the sensor is working fine, but when i move the phone and look at the screen it is going "crazy" what have i done wrong?
Henrik - 답글
i replace my lcd and my power sensor backlights turn on but display doesn't show anything any solution????
Zadd - 답글
댓글 쓰기
조회 통계:
지난 24시간: 47
지난 7일: 350
지난 30일: 1,032
전체 시간: 301,963
