이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
Remove the rear panel from the iPhone.
Remove the following screws securing the dock connector cable cover to the logic board:
One 1.5 mm Phillips screw
One 1.2 mm Phillips screw
Remove the metal dock connector cable cover.
Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
Remove the following four screws securing the cable cover to the logic board:
One 2.7 mm Phillips screw
One 2.6 mm Phillips screw
One 1.3 mm Phillips screw
Use the edge of a plastic opening tool to pry the cable cover tabs out of their slots cut into the EMI shield on the logic board.
Lift the cable cover from its edge nearest the top and remove it from the iPhone.
Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
Remove the rear camera from the iPhone.
Use a SIM eject tool or a paperclip to eject the SIM and its tray.
Remove the SIM and its tray.
Remove the five cables near the top of the logic board in the following order:
Headphone jack/volume button cable
Front facing camera cable
Digitizer cable
Display data cable
Power button cable (located underneath the headphone jack/volume button cable as shown in the second picture.)
Remove the 1.5 mm Phillips screw securing the grounding clip to the logic board near the headphone jack.
Use the tip of a spudger to pry the small grounding clip up off the logic board.
Carefully grasp the grounding clip and remove it from the iPhone.
이 단계에 사용된 도구:Standoff Screwdriver for iPhones$5.49-
Remove the 4.8 mm standoff screw near the headphone jack.
Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna from the logic board.
If present, peel the piece of black tape covering the hidden screw near the power button.
Remove the 2.6 mm Phillips screw securing the logic board near the power button.
Remove the following screws securing the logic board to the case:
One 2.5 mm Phillips screw near the vibrator motor
One 2.4 mm Phillips screw
One 3.6 mm standoff along the side of the logic board nearest the battery opening.
Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
Remove the logic board.
Use the edge of a plastic opening tool to carefully pry the metal front facing camera retainer away from the case of your iPhone.
Remove the front facing camera retainer.
이 단계에 사용된 도구:Tweezers$4.99-
Use the edge of a plastic opening tool to peel the upper antenna off the headphone jack.
Use a pair of tweezers to remove the upper antenna from the iPhone.
Use a plastic opening tool to start to pry the headphone jack out of its recess in the rear case.
Then use the opening tool to gently peel the microphone up from the adhesive securing it to the top of the rear case.
Remove the headphone jack assembly from the rear case, being careful not to tear the microphone flex cable.
Remove the 1.6 mm Phillips screw securing the mute switch bracket to the outer case.
Remove the four 1.5 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
Use a pair of tweezers to gently pull the silent switch bracket away from the outer case.
Carefully peel the headphone jack/volume button cables off the adhesive securing them to the rear case.
Remove the headphone jack cable assembly from the iPhone.
Use a pair of tweezers to remove the silent switch from the case of the iPhone.
다른 64명이 해당 안내서를 완성하였습니다.
댓글 4개
My iPhone 4s when on silent keeps jumping to loud by itself. Fixed it by wedging bit of folded cardboard inbetween battery and the ribbon wire which goes to switch
Same problem. Explain briefly. First timer.
Great guide. Easy to follow the step by step instructions with visual guide. But, what would make it slightly better for total beginners like me would be to provide a guide on how to put it back together again. Lol. Also if you could show how to exactly fit the new flex with the silent button as im having trouble keeping it in place/position.
Hi. I just made all steps to replace the conexion of the volume up/down that were damaged by water, I fixed it BUT: now the headphone may be making a contact that says to the iPhone that there's a jack inserted, then the speakers doesn't make any sound. All other thing looks fine, including the mic. Only the SIM card died, but it was very used and I will ask for a new one).
Any idea about what happens to the speaker or the headphone conexion?
I'm very tired after this difficult operation then I will back later. Thank you.
Guillermo, from Madrid, Spain.
