이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
Remove the rear panel from the iPhone.
Remove the following screws securing the dock connector cable cover to the logic board:
One 1.5 mm Phillips screw
One 1.2 mm Phillips screw
Remove the metal dock connector cable cover.
Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
Remove the following four screws securing the cable cover to the logic board:
One 2.7 mm Phillips screw
One 2.6 mm Phillips screw
One 1.3 mm Phillips screw
Use the edge of a plastic opening tool to pry the cable cover tabs out of their slots cut into the EMI shield on the logic board.
Lift the cable cover from its edge nearest the top and remove it from the iPhone.
Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
Remove the rear camera from the iPhone.
Use a SIM eject tool or a paperclip to eject the SIM and its tray.
Remove the SIM and its tray.
Remove the five cables near the top of the logic board in the following order:
Headphone jack/volume button cable
Front facing camera cable
Digitizer cable
Display data cable
Power button cable (located underneath the headphone jack/volume button cable as shown in the second picture.)
Remove the 1.5 mm Phillips screw securing the grounding clip to the logic board near the headphone jack.
Use the tip of a spudger to pry the small grounding clip up off the logic board.
Carefully grasp the grounding clip and remove it from the iPhone.
이 단계에 사용된 도구:Standoff Screwdriver for iPhones$5.49-
Remove the 4.8 mm standoff screw near the headphone jack.
Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna from the logic board.
If present, peel the piece of black tape covering the hidden screw near the power button.
Remove the 2.6 mm Phillips screw securing the logic board near the power button.
Remove the following screws securing the logic board to the case:
One 2.5 mm Phillips screw near the vibrator motor
One 2.4 mm Phillips screw
One 3.6 mm standoff along the side of the logic board nearest the battery opening.
Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
Remove the logic board.
이 단계에 사용된 도구:Tweezers$4.99-
Use the edge of a plastic opening tool to peel the upper antenna off the headphone jack.
Use a pair of tweezers to remove the upper antenna from the iPhone.
다른 88명이 해당 안내서를 완성하였습니다.
댓글 14개
where can u buy this piece, Ive been searching for about an hour now, a friend of mine tried to fix their phone and ripped this piece off... no idea how... any help?
The guide is very good and I succeeded in opening the iphone and fixing back again all the parts. Unfortunately, the wi-fi module still doesn't work, I don't know why. Anyway, many thanks to all ifixit staff, since they are helpful, efficient and kind. Alberto from Italy
Just completed replacing the battery and the wifi antenna. Went swimmingly. Thanks for the great directions. You guys rock! This fixed my 4s wifi grayed out issue. One thing to note, they wifi antenna needs to click into the socket to get a good connection. Put it together without checking this the first time and, no go.... Opened it up and made sure the connection was good and wahlah... AWSOME!
Hello, I had the issue with the grayed out wifi button. I replaced the upper antenna and the cellular antenna. When I turned on the phone the wifi was still greyed out. Does anyone has any other suggestions how I could possibly fix it.
Thanks
