주요 콘텐츠로 건너뛰기
iPhone 5c Screen Replacement
필요한 것
동영상 개요
  1. iPhone 5c Screen Replacement, Taping the display glass: 1 단계, 이미지 1/3 iPhone 5c Screen Replacement, Taping the display glass: 1 단계, 이미지 2/3 iPhone 5c Screen Replacement, Taping the display glass: 1 단계, 이미지 3/3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 5c Screen Replacement, Removing the Pentalobe screws: 2 단계, 이미지 1/1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.8 mm P2 Pentalobe screws on either side of the Lightning connector.
  3. iPhone 5c Screen Replacement, Starting the iSclack Opening Procedure: 3 단계, 이미지 1/3 iPhone 5c Screen Replacement, Starting the iSclack Opening Procedure: 3 단계, 이미지 2/3 iPhone 5c Screen Replacement, Starting the iSclack Opening Procedure: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iSclack
    $24.99
    구매
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5c that we recommend for anyone doing more than one repair on an iPhone 5, 5s, or 5c. If you aren't using the iSclack, skip to Step 5.
    • Close the handle on the iSclack, opening the suction-cup jaws.
    • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
    • The top suction cup should rest just above the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  4. iPhone 5c Screen Replacement, Finishing the iSclack Opening Procedure: 4 단계, 이미지 1/2 iPhone 5c Screen Replacement, Finishing the iSclack Opening Procedure: 4 단계, 이미지 2/2
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 8.
  5. iPhone 5c Screen Replacement, Manual Opening Procedure: 5 단계, 이미지 1/1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
  6. iPhone 5c Screen Replacement, Start lifting the front panel assembly: 6 단계, 이미지 1/2 iPhone 5c Screen Replacement, Start lifting the front panel assembly: 6 단계, 이미지 2/2
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  7. iPhone 5c Screen Replacement: 7 단계, 이미지 1/1
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  8. iPhone 5c Screen Replacement, Opening up the phone: 8 단계, 이미지 1/2 iPhone 5c Screen Replacement, Opening up the phone: 8 단계, 이미지 2/2
    • Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  9. iPhone 5c Screen Replacement: 9 단계, 이미지 1/1
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
  10. iPhone 5c Screen Replacement: 10 단계, 이미지 1/1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 5c Screen Replacement, Disconnecting the battery connector: 11 단계, 이미지 1/1
    • Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  12. iPhone 5c Screen Replacement: 12 단계, 이미지 1/1
    • Remove the following Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.3 mm screws
    • One 1.7 mm screw
    • One 3.25 mm screw
    • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 3.25 mm screw or the 1.7 mm screw in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
    • Be careful not to over-tighten the screws. If they don't fit easily when you are securing them, they may be the wrong size—don't force them.
  13. iPhone 5c Screen Replacement: 13 단계, 이미지 1/1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 5c Screen Replacement, Disconnecting the front panel assembly cables: 14 단계, 이미지 1/2 iPhone 5c Screen Replacement, Disconnecting the front panel assembly cables: 14 단계, 이미지 2/2
    • Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector.
    • Be sure to only pry up on the connector, and not on the socket on the logic board.
  15. iPhone 5c Screen Replacement: 15 단계, 이미지 1/3 iPhone 5c Screen Replacement: 15 단계, 이미지 2/3 iPhone 5c Screen Replacement: 15 단계, 이미지 3/3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the LCD cable connector.
    • The LCD and Digitizer connectors are on the same cable assembly, so prying the LCD connector up should disconnect both connectors. Double check that the two cables are fully disconnected before removing the display.
    • When reassembling your phone, the LCD cable may pop off its connector. A blank screen, or white lines on the display could be caused by a loose connection. Should this happen, reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  16. iPhone 5c Screen Replacement, Separating front panel assembly and rear case: 16 단계, 이미지 1/1
    • Remove the front panel assembly from the rear case.
결론
다른 724명이 해당 안내서를 완성하였습니다.
Walter Galan
694,773 평판
안내서 1,203개 작성하였습니다
댓글 29개
don't forget the 3 smaller of the 4 screws are different sizes on the silver panel!
djranoia - 답글
Yeah, I learned that one the hard way when I dropped the 1.6 mm screw onto my carpet. But, thank God, I found the screw after several minutes of searching for it. The entire display replacement from a cracked screen went nice and smooth. It actually tool me less than 20-minutes to complete the process. Thanks iFixit!!!
ebibbs -
How do I know if I'm ordering a white or black front screen? Also what's the difference between the 35$ from amazon or the 95$ from here?
Nicholas - 답글
The top and bottom on the back of the white iPhone 5 is made out of ceramic glass. The top and bottom on the back of the black iPhone 5 is made out of pigmented glass. Hope that helps! I use ReVampWholesales for parts, decently priced, just bought a black 5C full assembly (buttons and everything) for $44.50 with $8 shipping (pretty quick too). Amazon is very good too.
Andrew -
This guide misses a few things: after removing the old display, you will need to remove the silver backing/shield, the home button and the camera (be very careful when pulling the copper tape from the silver panel so not to tear it.) You will then need to place these in the new display. This is another 9? screws or so. I think the iPhone 5 page has this guide (it's pretty much the same thing.)
I always order the cheapest displays from Amazon (about $30 right now with free shipping for Prime members.) They always work just fine for me -- none of these parts is "officially from Apple" (they're all Chinese knockoffs.)
On a further note, be VERY careful when plugging the new screen to the mainboard - the FPC connector pins can BEND and BREAK if you force the connector. Broken pins require very careful hot air/reflow soldering of the mainboard and a new FPC connector: not recommended for novices!
Joshua - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 65
30일 전: 269
전체 시간: 418,218
