주요 콘텐츠로 건너뛰기
iPhone 6 SIM 카드 교체
필요한 것
  1. iPhone 6 SIM 카드 교체, SIM 카드: 1 단계, 이미지 2개 중 1개 iPhone 6 SIM 카드 교체, SIM 카드: 1 단계, 이미지 2개 중 2개
    • SIM 카드 추출 도구 또는 클립을 SIM 카드 트레이의 작은 구멍에 끼우세요.
    • 도구를 눌러 트레이를 꺼내세요.
    • 상당한 힘이 필요할 수 있습니다.
    Why isn’t this the first step in the process? Seems unnecessarily risky to fumble with popping the SIM in and out when you’ve already opened up the phone.
    Perrin Haley - 답글
    If you don’t have something small enough to open it, you can use the lever when the screen is off.
    Lucas Rowlands -
    I actually removed the simcard as the first step because I didn’t want to risk fumbling with an open phone (as someone previously mentioned)
    twcheng93 - 답글
  2. iPhone 6 SIM 카드 교체: 2 단계, 이미지 1개 중 1개
    • iPhone에서 SIM 카드 트레이 어셈블리를 분리하세요.
    • SIM 카드를 다시 끼울 때 트레이를 기준으로 올바른 방향인지 확인하세요.
    After reassembly phone would not detect SIM Card.
    During repair while components were out of phone I used that opportunity to straighten the back case that was bent. While straightening the back case I bent the thin edge of the back case by the SIM Card slot. SIM Card would click into place and seemed to make a good connection but the phone would not detect the SIM Card. After really straightening the back case by the SIM Card slot almost back to cherry the phone would now detect the SIM Card. The tray has to fit really flush with the case.
    johncrowley111 - 답글
    My flashlight has stopped working altogether. It was intermittent for a while. I believe them to be original. When I try to use the flash on my camera app, it flashes weakly but not enough do really help. Any chance the flex went bad or is there a logic board issue? My other two iphones with the same apps and the same updates are not having any problems.
    Jason Stein - 답글
    Bonjour j'ai un iphone 6 problème réseau
    karim kaladi - 답글
결론
기기를 재조립하려면 다음 지침을 역순으로 따르세요.
다른 71명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en ko
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
4다른 기여자 명과 함께
Walter Galan
701,346 평판
안내서 1,203개를 작성함
댓글 8개
Shouldn't the difficulty level on this one be "easy" rather than "moderate"? After all, you can do this with a paperclip.
Eric - 답글
Vous avez supprimé mon message mais je reviens le mettre à nouveau. C'est vraiment un astuce difficile à deviner . Vous ne cherchez qu'à remplir votre blog , c'est trivial remplacer sa carte sim
Annonce France -
Need to buy a new sim card holder
Richard LaVigne - 답글
Where can I buy a sim card complete holder
what does “,puk”, mean for a locked sim
Barbara Ann Dorn - 답글
can my iphone puk number be restored without going to the phone store ? how many numbers are in a ( puk)? why did my sim lock up on me ?
I know is kinda offtopic, but if anyone want to unlock iPhone free you can check Unlocky Tool :)
Vali Dragomir - 답글
How can u unlock an iPhone 6 so the sim can be used
Gavin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 57
지난 30일: 240
전체 시간: 53,989
