주요 콘텐츠로 건너뛰기
iPhone 7 Plus Pentalobe/펜타로브/별나사 교체
필요한 것
  1. iPhone 7 Plus Pentalobe/펜타로브/별나사 교체, Pentalobe/펜타로브/별나사: 1 단계, 이미지 1/1
    • 시작하기 전에 iPhone 배터리를 25% 이하로 방전하세요. 충전된 리튬-이온 배터리에 실수로 구멍이 생기면 화재를 일으키거나 폭발할 수 있습니다.
    • 분해를 시작하기 전에 iPhone 전원을 끄세요.
    • iPhone 하단 가장자리에 위치한 3.4mm pentalobe/펜타로브/별나사 두 개를 빼세요.
    • iPhone 디스플레이를 열게되면 방수 씰이 손상됩니다. 이 단계를 수행하기 전에 교체용 씰을 준비하거나 씰없이 iPhone을 재조립할 경우 액체에 노출되지 않도록 주의하세요.
    The recommendation of discharging the battery is completely unnecessary. Even a 25% charged battery can explode. Completely ridiculous suggestion.
    pargoff - 답글
    The risk of thermal runaway on these batteries decreases with the battery's SOC (state of charge). Below 50% charge the risk is fairly low, and at 25% charge the risk of a thermal event is near zero. If I recall correctly, the same suggestion appears in Apple's official (non-public) service manuals for the iPhone.
    Jeff Suovanen -
    @jeffsu Yes, that is correct. Apple does require all certified staff to discharge the battery below 25%. This is an industry standard for all LiION batteries. If you don’t want to do this, just make sure to not puncture the battery and disconnect it first thing.
    iHelpU.Tech - 답글
    Hang on a second here, doesn’t the Ifixit part I ordered come with the seals? The display assembly? It doesn’t. Now I have to wait another week?!
    Vanessa Pinter - 답글
    How do you turn off if the screen isn’t responding to touch?
    adam - 답글
    The replacement battery came with the seal—but how do you put it on???
    lkollar - 답글
    Instructions for replacing the seal are here: iPhone 디스플레이 접착제 교체
    bester - 답글
    I just found the instructions on how to install the seals AFTER I was completed and had to figure it out. Maybe, just maybe you should link this somewhere on the guild instead of buried in a comment. Just a thought.
    Charles Meitin - 답글
    Step 1 is: Read through all the steps and comments or the method prior to starting on this Step 1. There's a lot of much needed information and experience that you can learn from which will reduce the chance of struggling, wasting time or even breaking your device.
    My favourites are:
    Use a hot water bottle.
    Label all screws you remove with their size and location on a piece of paper with double sided sticky tape.
    Test the lightning assembly at step 13
    There is a Standoff driver bit in the box, don't use a screwdriver.
    etc...
    Neil Eriksen - 답글
    A tip for looking out for all those little screws. I used an ice block tray, for all the little screws etc. I numbered each with the step number, as in the instructions, but not all steps have bits to look out for. Where two different size screws are used I had a tray for each size and marked step a and step b. For this I coloured each tray sticker with the colour of the screw as shown in the instructions. All this worked a treat with no confusion or using the wrong part.
    Herb
    Herb Adler - 답글
    The screw size for those with a screw set is P2.
    Gareth Flandro - 답글
결론
기기를 다시 조립하려면 이 지침을 역순으로 따르세요.
다른 33명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en ko
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Evan Noronha
회원 가입일: 02/05/15
223,466 평판
안내서 168개 작성하였습니다
댓글 4개
Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
Cooper Chase - 답글
Hey Cooper,
There is no seal on the screw. The head of the screw simply pushes against the lip of the screw well, without using any sort of pneumatic seal, o-ring etc.
As Talon says, it is part of the casing.
Harry Rowse -
I not recall seeing one. If there is one I would expect it to be part of the casing.
Talon - 답글
as the costumer said, there is a sealant but not noticeable
Mark Perick Quemado - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 89
전체 시간: 19,962
