주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 8 Disassembly
필요한 것
    1. iPhone 8 Disassembly, Power Off: 1 단계, 이미지 1개 중 1개
      • First turn off the device to avoid any damage during disassembly.
      댓글 쓰기
    2. iPhone 8 Disassembly, Unscrew: 2 단계, 이미지 1개 중 1개
      • Remove the two screws to the left and right of the charging/headphone jack with a suitable screwdriver
      댓글 쓰기
    3. iPhone 8 Disassembly, Loosen the display: 3 단계, 이미지 2개 중 1개 iPhone 8 Disassembly, Loosen the display: 3 단계, 이미지 2개 중 2개
      • Work your way around the iphone with a pick (or fingernail). Start in one corner, to loosen the adhesive and retaining tabs. After that, the display should lay loosely with a gap of about 2mm on the phone.
      • Warning: pry carefully at the top of the screen. Here the display is not yet freed from the case!
      댓글 쓰기
    4. iPhone 8 Disassembly, Open the cell phone: 4 단계, 이미지 1개 중 1개
      • Now you can open the display to the left. Attention: no further than 90⁰, otherwise the ribbon cables of the display will break off.
      댓글 쓰기
    5. iPhone 8 Disassembly, Detach the display cable: 5 단계, 이미지 2개 중 1개 iPhone 8 Disassembly, Detach the display cable: 5 단계, 이미지 2개 중 2개
      • Under this sheet metal are all the important cables of the phone. This sheet is fastened with four small Phillips screws. After removing the sheet, carefully lift the two display cable connectors with your fingernail until they unplug from the board.
      댓글 쓰기
    6. iPhone 8 Disassembly, Detach the second display cable: 6 단계, 이미지 1개 중 1개
      • Under this sheet are the cable for the speaker/front camera and the cable for the main camera. First, loosen the cable for the front camera to remove the display completely.
      댓글 쓰기
    7. iPhone 8 Disassembly, Remove Camera and Bluetooth Antenna: 7 단계, 이미지 2개 중 1개 iPhone 8 Disassembly, Remove Camera and Bluetooth Antenna: 7 단계, 이미지 2개 중 2개
      • The camera sits under this sheet metal. The sheet metal is held in place by two screws. After removing the sheet metal, unplug the camera cable and remove the camera.
      • The Bluetooth antenna is curved into the corner of the phone. It is secured to the housing with a screw and to the circuit board with another screw
      댓글 쓰기
    8. iPhone 8 Disassembly, Removing the rear microphone: 8 단계, 이미지 1개 중 1개
      • The microphone is attached to the housing with a screw and to the back panel with a screw. Both screws must be removed and when doing so note that the microphone is also glued.
      댓글 쓰기
    9. iPhone 8 Disassembly, Remove NFC Cover: 9 단계, 이미지 1개 중 1개
      • Now remove the cover of the NFC device. After removing the cover, the board is only held in place by three screws.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
Juan Garcia님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Jan Phönix
회원 가입일: 12/02/21
385 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 46
지난 30일: 205
전체 시간: 1,775
