주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone Camera Repair
필요한 것
동영상 개요
  1. iPhone Camera Repair, main camera: 1 단계, 이미지 2개 중 1개 iPhone Camera Repair, main camera: 1 단계, 이미지 2개 중 2개
    • Today, REWA LAB will share with you a repair case of an iPhone camera and walk you through some knowledge of iPhone camera repair.
    • Open the phone camera. When taking photos with the wide-angle camera, cracks appear. The ultra-wide camera works fine. We can judge that the optical filter of the wide-angle camera is damaged.
    댓글 쓰기
  2. iPhone Camera Repair: 2 단계, 이미지 3개 중 1개 iPhone Camera Repair: 2 단계, 이미지 3개 중 2개 iPhone Camera Repair: 2 단계, 이미지 3개 중 3개
    • We can judge that the optical filter of the wide-angle camera is damaged. Then we disassemble the phone and try to repair the camera. First of all, put the camera on the specialized Heating Platform at 100 °C.
    • When the temperature reaches 100 °C, remove black adhesive around the camera with a Sculpture Knife. Then pry up the wide-angle camera.
    • Attach the camera to the specialized holder. Before repair, apply protection tape to the camera.
    댓글 쓰기
  3. iPhone Camera Repair: 3 단계, 이미지 3개 중 1개 iPhone Camera Repair: 3 단계, 이미지 3개 중 2개 iPhone Camera Repair: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Separate the camera edges with a Sculpture Knife. Next, remove the metal cover with Hot Air Gun at 120 °C.
    • Keep heating with Hot Air Gun at 120 °C. Remove black adhesive with Tweezers. Apply some Paste Flux.
    • Separate the motor from the CMOS with ultrathin Soldering Iron at 380 °C
    댓글 쓰기
  4. iPhone Camera Repair: 4 단계, 이미지 2개 중 1개 iPhone Camera Repair: 4 단계, 이미지 2개 중 2개
    • It can be seen that the optical filter is broken while the motor and blue lens are good. If the motor is damaged, the camera will fail to focus or shake. A motor replacement can help you solve the problem.
    • The middle part of the motor is the blue lens. If the blue lens is damaged, the camera will become blurry. The solution is to replace the blue lens.
    • Then we replace the cracked optical filter with a new one.
    댓글 쓰기
  5. iPhone Camera Repair: 5 단계, 이미지 3개 중 1개 iPhone Camera Repair: 5 단계, 이미지 3개 중 2개 iPhone Camera Repair: 5 단계, 이미지 3개 중 3개
    • Apply some UV adhesive to the broken optical filter.
    • Put the new optical filter in position.
    • Solidify with a UV Lamp.
    댓글 쓰기
  6. iPhone Camera Repair: 6 단계, 이미지 3개 중 1개 iPhone Camera Repair: 6 단계, 이미지 3개 중 2개 iPhone Camera Repair: 6 단계, 이미지 3개 중 3개
    • Remove side adhesive with Hot Air Gun.
    • Then push the cracked optical filter out with the specialized holder.
    • Remove residual shards and black adhesive with Hot Air Gun.
    댓글 쓰기
  7. iPhone Camera Repair: 7 단계, 이미지 3개 중 1개 iPhone Camera Repair: 7 단계, 이미지 3개 중 2개 iPhone Camera Repair: 7 단계, 이미지 3개 중 3개
    • Then remove dust spots with a specialized swab. Please be extremely careful not to damage the CMOS during operation. If the CMOS is damaged, the camera will be unrepairable.
    • Then apply some UV adhesive and a new optical filter. Solidify with UV Lamp.
    댓글 쓰기
  8. iPhone Camera Repair: 8 단계, 이미지 3개 중 1개 iPhone Camera Repair: 8 단계, 이미지 3개 중 2개 iPhone Camera Repair: 8 단계, 이미지 3개 중 3개
    • Then we assemble the camera. Apply some Paste Flux around the motor. Solder the motor with the CMOS with Soldering Iron. Clean the camera with alcohol.
    • Next, we install the wide-angle camera for testing. The camera works fine. Apply B7000 to fix the wide-angle camera. That’s all for the optical filter replacement of iPhone camera.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
REWA
회원 가입일: 11/24/20
19,375 평판
안내서 55개를 작성함
2가이드 댓글
Good job! But, the cost of labor and material is not economical. It is still wise to buy the whole camera module as a replacement. Easier and more practical.
On the other hand, if the viewer opted to do the filter replacement, this is a great reference since Rewa is a reputable company. Thank you for sharing this useful guide.
Jojo - 답글 공유
Incrível! Parabéns!!
Daan.ll - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 28
지난 7일: 150
지난 30일: 842
전체 시간: 31,691
