주요 콘텐츠로 건너뛰기
iPhone XS Max Display Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPhone XS Max Display Assembly Replacement, Display Assembly: 1 단계, 이미지 1/2 iPhone XS Max Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Remove four Y000 screws securing the logic board cover bracket, of the following lengths:
    • Two 1.1 mm screws
    • One 1.5 mm screw
    • One 3.7 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  2. iPhone XS Max Display Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  3. iPhone XS Max Display Assembly Replacement: 3 단계, 이미지 1/2 iPhone XS Max Display Assembly Replacement: 3 단계, 이미지 2/2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  4. iPhone XS Max Display Assembly Replacement: 4 단계, 이미지 1/2 iPhone XS Max Display Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the three Y000 screws securing the display connector bracket:
    • Two 1.5 mm screws
    • One 1.1 mm screw
  5. iPhone XS Max Display Assembly Replacement: 5 단계, 이미지 1/1
  6. iPhone XS Max Display Assembly Replacement: 6 단계, 이미지 1/2 iPhone XS Max Display Assembly Replacement: 6 단계, 이미지 2/2
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  7. iPhone XS Max Display Assembly Replacement: 7 단계, 이미지 1/2 iPhone XS Max Display Assembly Replacement: 7 단계, 이미지 2/2
    • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. iPhone XS Max Display Assembly Replacement: 8 단계, 이미지 1/2 iPhone XS Max Display Assembly Replacement: 8 단계, 이미지 2/2
    • Use a spudger or fingernail to pry the digitizer cable connector up from its socket.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  9. iPhone XS Max Display Assembly Replacement: 9 단계, 이미지 1/3 iPhone XS Max Display Assembly Replacement: 9 단계, 이미지 2/3 iPhone XS Max Display Assembly Replacement: 9 단계, 이미지 3/3
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
  10. iPhone XS Max Display Assembly Replacement: 10 단계, 이미지 1/1
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
429,019 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,430개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 422
