주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPod 1st Generation Hard Drive Cable Replacement
필요한 것
    1. iPod 1st Generation Hard Drive Cable Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      댓글 쓰기
    2. iPod 1st Generation Hard Drive Cable Replacement: 2 단계, 이미지 1개 중 1개
      • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      댓글 쓰기
    3. iPod 1st Generation Hard Drive Cable Replacement: 3 단계, 이미지 1개 중 1개
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      댓글 쓰기
    4. iPod 1st Generation Hard Drive Cable Replacement: 4 단계, 이미지 1개 중 1개
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      댓글 쓰기
    5. iPod 1st Generation Hard Drive Cable Replacement: 5 단계, 이미지 1개 중 1개
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      • Lift the rear panel away from the iPod.
      댓글 쓰기
    1. iPod 1st Generation Hard Drive Cable Replacement, Hard Drive: 6 단계, 이미지 1개 중 1개
      • Lift the battery up from the adhesive holding it to the iPod.
      • Lay the battery next to the iPod (it is still connected to the logic board).
      댓글 쓰기
    2. iPod 1st Generation Hard Drive Cable Replacement: 7 단계, 이미지 1개 중 1개
      • Carefully disconnect the orange ribbon cable from the hard drive.
      • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
      • Lift the hard drive out of the iPod.
      댓글 쓰기
    1. iPod 1st Generation Hard Drive Cable Replacement, Hard Drive Cable: 8 단계, 이미지 1개 중 1개
      • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
      댓글 쓰기
    2. iPod 1st Generation Hard Drive Cable Replacement: 9 단계, 이미지 1개 중 1개
      • Peel up the gray rubber bumper near the hard drive ribbon to reveal the T6 Torx screw beneath.
      • Remove the newly revealed T6 Torx screw.
      댓글 쓰기
    3. iPod 1st Generation Hard Drive Cable Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the remaining 3 T6 Torx screws from the logic board.
      댓글 쓰기
    4. iPod 1st Generation Hard Drive Cable Replacement: 11 단계, 이미지 1개 중 1개
      • Slide the logic board away from the port end of the casing and lift it out of the iPod.
      댓글 쓰기
    5. iPod 1st Generation Hard Drive Cable Replacement: 12 단계, 이미지 1개 중 1개
      • Use a spudger to carefully disconnect the orange hard drive cable from beneath the scroll wheel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 43
전체 시간: 9,964
