주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPod 2nd Generation Display Replacement
필요한 것
    1. iPod 2nd Generation Display Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      댓글 쓰기
    2. iPod 2nd Generation Display Replacement: 2 단계, 이미지 1개 중 1개
      • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      댓글 쓰기
    3. iPod 2nd Generation Display Replacement: 3 단계, 이미지 1개 중 1개
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      댓글 쓰기
    4. iPod 2nd Generation Display Replacement: 4 단계, 이미지 1개 중 1개
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      댓글 쓰기
    5. iPod 2nd Generation Display Replacement: 5 단계, 이미지 1개 중 1개
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      댓글 쓰기
    6. iPod 2nd Generation Display Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
      댓글 쓰기
    1. iPod 2nd Generation Display Replacement, Hard Drive: 7 단계, 이미지 1개 중 1개
      • Peel up the metallic tape attached to the top of the battery.
      댓글 쓰기
    2. iPod 2nd Generation Display Replacement: 8 단계, 이미지 1개 중 1개
      • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
      댓글 쓰기
    3. iPod 2nd Generation Display Replacement: 9 단계, 이미지 1개 중 1개
      • Carefully disconnect the orange ribbon cable from the hard drive.
      • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
      • Lift the hard drive out of the iPod.
      댓글 쓰기
    1. iPod 2nd Generation Display Replacement, Hard Drive Cable: 10 단계, 이미지 1개 중 1개
      • For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
      • Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
      댓글 쓰기
    2. iPod 2nd Generation Display Replacement: 11 단계, 이미지 1개 중 1개
      • Slide the hard drive cable out of its connector.
      댓글 쓰기
    1. iPod 2nd Generation Display Replacement, Display: 12 단계, 이미지 1개 중 1개
      • Lift the blue hard drive mounting bracket out of the iPod.
      댓글 쓰기
    2. iPod 2nd Generation Display Replacement: 13 단계, 이미지 1개 중 1개
      • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
      댓글 쓰기
    3. iPod 2nd Generation Display Replacement: 14 단계, 이미지 1개 중 1개
      • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
      • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
      댓글 쓰기
    4. iPod 2nd Generation Display Replacement: 15 단계, 이미지 1개 중 1개
      • Remove the 8 T6 Torx screws from the logic board.
      댓글 쓰기
    5. iPod 2nd Generation Display Replacement: 16 단계, 이미지 1개 중 1개
      • Lift the logic board up enough to disconnect the orange touch wheel cable.
      • Lift the logic board out of the iPod.
      댓글 쓰기
    6. iPod 2nd Generation Display Replacement: 17 단계, 이미지 1개 중 1개
      • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
      댓글 쓰기
    7. iPod 2nd Generation Display Replacement: 18 단계, 이미지 1개 중 1개
      • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
      댓글 쓰기
    8. iPod 2nd Generation Display Replacement: 19 단계, 이미지 1개 중 1개
      • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
      • Lift the display off the logic board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 58
전체 시간: 8,393
