주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPod 2nd Generation Rear Panel Replacement
필요한 것
    1. iPod 2nd Generation Rear Panel Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      댓글 쓰기
    2. iPod 2nd Generation Rear Panel Replacement: 2 단계, 이미지 1개 중 1개
      • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      댓글 쓰기
    3. iPod 2nd Generation Rear Panel Replacement: 3 단계, 이미지 1개 중 1개
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      댓글 쓰기
    4. iPod 2nd Generation Rear Panel Replacement: 4 단계, 이미지 1개 중 1개
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      댓글 쓰기
    5. iPod 2nd Generation Rear Panel Replacement: 5 단계, 이미지 1개 중 1개
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      댓글 쓰기
    6. iPod 2nd Generation Rear Panel Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
2가이드 댓글
According to this site: https://www.lifewire.com/history-ipod-cl.... The thickness of the various HD sizes is different.
“4 x 2.4 x 0.78 inches - 5 GB Model
4 x 2.4 x 0.72 inches - 10 GB Model
4 x 2.4 x 0.84 inches - 20 GB Model”
It makes some sense from other information I’ve read, but I don’t find any discussion of a thick and thin version. Is the back for the 20GB model thicker/deeper than the 10GB model? Thanks for another great guide.
Rusty Lingenfelter - 답글 공유
no, the model is same. but 2gen is a little thicker than 1 gen. apple use diffrent types of rubber cushion to fits in it. if you want change a bigger disk, make sure there is enugh space for battery
Montary - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 56
전체 시간: 7,143
