주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPod 3rd Generation Hard Drive Cable Replacement
필요한 것
    1. iPod 3rd Generation Hard Drive Cable Replacement, Case: 1 단계, 이미지 1개 중 1개
      • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
      댓글 쓰기
    2. iPod 3rd Generation Hard Drive Cable Replacement: 2 단계, 이미지 3개 중 1개 iPod 3rd Generation Hard Drive Cable Replacement: 2 단계, 이미지 3개 중 2개 iPod 3rd Generation Hard Drive Cable Replacement: 2 단계, 이미지 3개 중 3개
      • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
      • You may need to rock the pick back and forth to slide it in farther.
      • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
      • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
      • After all five tabs along the right side are free, the case should open easily.
      댓글 쓰기
    3. iPod 3rd Generation Hard Drive Cable Replacement: 3 단계, 이미지 1개 중 1개
      • The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
      • Open the case like a book with the dock connector at the top, and lay the rear panel next to the front half of the iPod.
      댓글 쓰기
    4. iPod 3rd Generation Hard Drive Cable Replacement: 4 단계, 이미지 2개 중 1개 iPod 3rd Generation Hard Drive Cable Replacement: 4 단계, 이미지 2개 중 2개
      • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
      • The headphone jack connector is unusually tall. When prying, be careful to not separate the lower, plastic part of the connector from the ribbon cable. Pry between the connector and the socket, not between the two halves of the connector.
      댓글 쓰기
    1. iPod 3rd Generation Hard Drive Cable Replacement, Hard Drive Cable: 5 단계, 이미지 1개 중 1개
      • Lift up the hard drive with one hand and carefully disconnect the hard drive ribbon from the logic board.
      • Lift the hard drive out of the iPod.
      댓글 쓰기
    2. iPod 3rd Generation Hard Drive Cable Replacement: 6 단계, 이미지 1개 중 1개
      • Peel back the metallic tape connecting the hard drive ribbon to the blue mounting bracket.
      댓글 쓰기
    3. iPod 3rd Generation Hard Drive Cable Replacement: 7 단계, 이미지 1개 중 1개
      • Use a spudger to carefully disconnect the orange ribbon cable from the hard drive.
      • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
      댓글 쓰기
    4. iPod 3rd Generation Hard Drive Cable Replacement: 8 단계, 이미지 1개 중 1개
      • Lift the hard drive mounting bracket and cable off the hard drive.
      댓글 쓰기
    5. iPod 3rd Generation Hard Drive Cable Replacement: 9 단계, 이미지 1개 중 1개
      • Peel up the metallic tape holding the hard drive ribbon to the blue mounting bracket.
      댓글 쓰기
    6. iPod 3rd Generation Hard Drive Cable Replacement: 10 단계, 이미지 1개 중 1개
      • Peel up the black tape securing the hard drive ribbon to the mounting bracket.
      • The hard drive ribbon is now free from the iPod.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 66
전체 시간: 11,019
