주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iRobot Braava 320 Wheel Replacement
필요한 것
    1. iRobot Braava 320 Wheel Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Flip your device over and locate the battery cover.
      • The battery cover is located in the center of the device in between both wheels.
      댓글 쓰기
    2. iRobot Braava 320 Wheel Replacement: 2 단계, 이미지 1개 중 1개
      • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
      • The screw does not remove, it stays attached to the cover.
      댓글 쓰기
    3. iRobot Braava 320 Wheel Replacement: 3 단계, 이미지 2개 중 1개 iRobot Braava 320 Wheel Replacement: 3 단계, 이미지 2개 중 2개
      • Gently remove the battery from the tray and disconnect the battery cable.
      • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
      • To reinstall the cable, hold it near the end and gently push it in the connector.
      댓글 쓰기
    1. iRobot Braava 320 Wheel Replacement, Body Shell and Control Panel: 4 단계, 이미지 1개 중 1개
      • With the battery removed, rotate your device so the front of it is facing you.
      • Remove the four 10mm Phillips #2 screws that attach the shell.
      댓글 쓰기
    2. iRobot Braava 320 Wheel Replacement: 5 단계, 이미지 2개 중 1개 iRobot Braava 320 Wheel Replacement: 5 단계, 이미지 2개 중 2개
      • Using both hands, hold the device together while you flip it over.
      • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
      댓글 쓰기
    1. iRobot Braava 320 Wheel Replacement, Wheel: 6 단계, 이미지 3개 중 1개 iRobot Braava 320 Wheel Replacement, Wheel: 6 단계, 이미지 3개 중 2개 iRobot Braava 320 Wheel Replacement, Wheel: 6 단계, 이미지 3개 중 3개
      • To remove the wheel covers, hold the wheel in place with one hand while turning the cover clock-wise with the other.
      • The cover should come off as soon as you hear a 'click' sound.
      • When replacing the cover, align the notches on the cover just to the right of the ones on the wheel.
      댓글 쓰기
    2. iRobot Braava 320 Wheel Replacement: 7 단계, 이미지 3개 중 1개 iRobot Braava 320 Wheel Replacement: 7 단계, 이미지 3개 중 2개 iRobot Braava 320 Wheel Replacement: 7 단계, 이미지 3개 중 3개
      • Using a small Flathead screwdriver, remove the small black clip in the center of the wheel.
      • To ensure the clip does not fly off, place your hand over the wheel to cover it as you remove the clip.
      댓글 쓰기
    3. iRobot Braava 320 Wheel Replacement: 8 단계, 이미지 3개 중 1개 iRobot Braava 320 Wheel Replacement: 8 단계, 이미지 3개 중 2개 iRobot Braava 320 Wheel Replacement: 8 단계, 이미지 3개 중 3개
      • Once the small black clip is removed, the wheel should come off by gently pulling on it.
      • Be careful not to lose the two small chrome pieces located on each side of the wheel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ruven Tapia-Vargas
회원 가입일: 02/28/17
409 평판
안내서 1개를 작성함
USF Tampa, Team S1-G3, Nance Spring 2017 USF Tampa, Team S1-G3, Nance Spring 2017 회원
USFT-NANCE-S17S1G3
4 회원들
안내서 20개를 작성함
1가이드 댓글
O roteiro descritivo para a troca das rodas do Braava foi muito útil. Obrigada!
Vanilda Chueiri - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 35
전체 시간: 10,719
